TBR7 replacement battery
what's a good replacement battery for these bikes? they only seem to last about 9 months for me
Was a toss up between the Zipp and Mighty Max.
I wound up going with the Zipp based on dimensions, it was basically a dead drop in fit. The Mighty Max will need a foam block for the gap. Either are good and fair enough price point, my Zipp I have had in for a good while Here are links to both Zipp https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Mighty https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
I've recently bought two Zipp batteries. One was defective and was dead in a weak and would not take a charge. Chrome Battery Store was quick to send out a new battery with no questions asked. Didn't even have to send to old battery back. Battery comes with an 18 month warranty.
Fwiw. Might be a good idea to check connections to ensure your battery is.getting a good charge.... the tbr7 charging system is.not the most robust so those connections matter more... also some ncp2 or similar might be a good idea as well
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
