09-25-2020, 11:58 AM | #1 |
New to Zongshen from Tennessee
I recently traded for a Zongshen 200 enduro. The bike has a decal on the exhaust that reads XZXM and a decal on the side that reads "Extreme 200 off road". I have not been able to find anything on google about this bike. Does anyone know what year and model this may be?
09-25-2020, 02:47 PM | #2 |
I'm guessing its a Zongshen but the motor reads "Max Motor"
09-26-2020, 05:27 PM | #4 |
Well, looks like the good old LZX/ZS200 GY-2, aka as "Zongshen Sierra" in the states. Oldest models I know of are 2005-2006, mine is a 2007, and there are new unused examples sold in Greece from 2012 or so. Yours looks like a later model year, judging by the exhaust, unless it's an aftermarket one. Later model years have a very similar one to yours, but the branding is different. Mine has the older type with a smaller port and a bolted-on heat shield.
Yours looks pretty stock except for the golden chain (is it a sealed o-ring type?). The stickers (or lack of them) exhibit quite some variation between markets and model years. Welcome aboard, Zongshen brother, BTW Edit: by looking at it better, it seems like it's missing all indicator lights, no rear-view mirrors, no license plate, and no rear cargo rack. May it has been modified for use as a pure Enduro/MX? |
09-28-2020, 11:21 AM | #5 |
Thanks for the insight CR,
You are correct it is missing several enduro parts as I assume someone just was wanting it to be for offroad only. It ran when I first picked it up but now I cant get a spark at all. I rode it for about 1000 feet and it bogged down and stalled and I had to push it home. I hope I didnt come across a lemon here as for it is a nice looking bike and would work well on the trails here in TN. As for the sealed O ring type. Im not really sure. Thanks again pal. |
09-28-2020, 01:27 PM | #6 |
Check ignition grounds, and try a fresh plug.
09-28-2020, 04:03 PM | #7 | |
09-29-2020, 07:34 AM | #8 |
An easy fix/cheap insurance for spark & ignition related problems is to have a spare CDI. Mine was still going strong on with the OEM one, but I ordered a new spare one from AliExpress and swapped it out just in case:
https://www.aliexpress.com/item/1923...27424c4dPlkxiK Just make sure you're ordering the AC-CDI unit. It wouldn't hurt to remove the saddle and the right side panel (where the CDI and -normally- the blinker relay is) and inspect the wiring, rectifier and battery, just in case. Also, remove the front cowl and inspect the wiring terminals there too, as the waterproofing in that spot is, let's say, less than stellar. There should also be a large diode housed in the front cowl. Without that, starting up using the e-starter might induce negative voltage spikes, very bad for electronics. Other things to watch out for, is the front brake hose: depending on how it was routed on the left fork leg (esp. if inside the protective leg's "boot"), it might have been rubbing against the fork in several places. Also, mine was cracked due to age in several parts, so I swapped it out just in case (actually I had to swap the entire front brake assy because local mechanics insisted that I could not just swap out the hose, but that's another story ) |
09-29-2020, 11:46 AM | #9 |
Great bike. I wish I could find one. Hard to come by but a truly awesome bike.
Just read Spuds sticky's. There is a ton of info on these bikes. Nice find!
10-01-2020, 07:28 AM | #10 | |
Thanks for the help Everyone! |
Tags |
mzxm 200 zong ? |
