04-13-2008, 09:44 PM | #1 |
carb adjustment on hi bird 250cc
i adjusted the carb on my 250cc,put in a cone filter, it has the same carb( mikuni pz30)
so i adjusted the clip and un screwed the ("what's the name of that screw again") just turned it out a little .. but i notice no difference also both ways (stock or adjusted) The idle starts out really low and as it warms up the idle will increase. anyone know why?Ive adjusted the idlescrew out so it runs a little faster but at first ineed to feather the throttle to keep it running . |
04-13-2008, 09:47 PM | #2 |
Mine is cold natured.I have to throtle as well untill it warms up then it purrs like a kitty.
04-13-2008, 11:35 PM | #3 |
Guest
Posts: n/a
did you move the clip to the bottom position on the needle? also..a good starting point (and where mine currently is) on the air screw is two turns out from flush.
04-14-2008, 01:15 AM | #4 |
yes i moved the clip to the bottom, and also can someone put a pic of the air screw just so im sure??
