08-25-2020, 04:20 AM | #1 |
Lowering Hawk
On the Amazon page for the Hawk, the description recommends the bike for riders over 5'8". I am shorter (5'4"-5'5"ish) and am wondering if there is an easy way to lower the bike to a comfortable height for me (I'd like to be able to flat foot it since I'm a new rider). Perhaps an adjustable spring, or shaving seat foam, or just a certain part I should buy?
08-25-2020, 07:26 AM | #2 |
So you're 5'4", how much do you weigh? The reason I ask is you can buy a shorter monoshock for about $80. If you're a heavy person you're not gonna want to go any shorter than 290mm which will drop the rear 3". But if you're a lighter person you could go as short as 280mm which would be a 4" drop. That combined with dropping the forks 2" in the triple tree should put you close to flat footing it. Also CSC sells a lower profile seat for it.
08-26-2020, 02:54 AM | #3 | |
Edit: and possibly a link to the seat; I can't seem to find it. Thanks! |
08-26-2020, 09:45 PM | #4 |
Your height doesnt matter as much as inseam.
You can lower the rear about 3 inches without needing to then also shorten the kickstand. That will put the seat height around 31 to 32ish inches. Seat https://store.cscmotorcycles.com/TT2...sc-300ttkt.htm
08-27-2020, 04:23 AM | #5 | |
08-27-2020, 06:52 AM | #6 |
That's going to depend on your inseam I'm 5'6 with a 29 or 30 inch inseam can't remember. but my xpect has a 32 inch seat hight and if I really stretch I can almost get both feet on the ground usaly I just put one foot down. or if both are down usaly the ball of both feet are touching.
Current Bikes 2019 Lifan Xpect 2016 Harley Davidson Roadster |
08-27-2020, 07:53 PM | #7 |
That would be with a 20 to 25mm shorter rear shock.
08-27-2020, 08:50 PM | #8 | |
08-27-2020, 11:06 PM | #9 |
Seat
That seat is in the accessories and it's kind of pricey!
08-28-2020, 01:41 AM | #10 |
Yeah...where would I find a monoshock?
Tags |
hawk, lower, rps |
