2020 Orion RXB250L
SOLD to the first person to see it
New 2020 Orion RXB250L dual sport motorcycle. Made in China with a clone four stroke Honda engine in a clone 2107 era KTM frame. Research the brand if not familiar, as quality and reliability are impressive. Arguably the best China bike available. Bike is better than new, has all needed updates and upgrades. Upgrades include 12 tooth countershaft sprocket, valve adjustment, fork oil swap, Nibbi performance carburetor, stainless steel exhaust header, Kawasaki KX250 shock, Acerbis handguards, Oury grips, and Regina chain. The bike has been run through four complete break in heat cycles in neutral, as well as three more with the transmission engaged. Oil for a oil change when break in is complete is included. The bike has not been ridden...at all...zero miles as indicated by the odometer picture is true and honest. FB makes you put a minimum of 300 miles in to place the ad. Also included are a new set of supermoto rims as well as two new supermoto tires (although one is back ordered and has not arrived yet), new tubes, and is also a new sprocket for the rear supermoto rim. But wait...there's MORE! A brand new aluminum swingarm with all needed hardware is included. A 4 degree timing key which bumps up power is included but not installed. All items removed from the bike: stock chain, carb, shock, exhaust header, and all emissions related items are included in the sale. Only blemish is a molding defect in the front fender, not noticeable as I covered it up with a Regina Chain decal. There is a burgeoning market for performance upgrades for this bike. Henner Motorsports is leading the charge. $2500 for everything Located in the Finger Lakes area of Upstate NY. Zip is 14882. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Rokoneer; 08-18-2020 at 07:01 PM. |
Oh yeah, you betcha. Have receipts for over $3500...
