07-24-2020, 08:36 PM | #1 |
Changed to the 40r sprocket
Hello my fellow Chinariders! So I switched the rear sprocket on the Brozz to a 40 tooth. Also changed the front same 17t and new chain. I haven't been able to do the washer on the front sprocket yet waiting on supplies from the ZON. Top speed is way better without stressing the engine as much. Ever since then power up wheelies in first also clutch ups my chain seems to jump the sprocket. Giving this nasty clunking sound before the power picks up. Could this be caused by the front sprocket being off a little as Herbie explained in one of my earlier posts? I bought a new clutch assembly in case I have to dig into it. I'm hoping it's just the little space on the front sprocket causing it to jump. Any input would be appreciated.
07-25-2020, 05:17 PM | #2 | |
07-25-2020, 05:31 PM | #3 |
Thanks Herbie I figured that's what it was. I put the old stock one back on and the clunking disappeared. I have the assorted washers and bolts coming for when I wanna go back to the 40r again. It definitely is the perfect combo for the streets. No more revving it out to keep out of traffics way. Thanks again for the response sometimes I feel like I can answer my own questions by now with all the knowledge learned from you guys. I just like to have that little but of reassurance from someone with experience on the matter. The Brozz is holding up strong I have to do a follow up post on that. I see you got yourself a nice bike now CONGRATS!
07-25-2020, 06:31 PM | #4 |
I'm glad the Brozz is doing good for you, it's really a good bike. Thanks, I do like my new bike but I really miss my Brozz. I may get a china bike at some point again but next time I think it will be a dirt bike.
07-26-2020, 08:20 PM | #5 |
Hey Brozzanator, could you help me and link to the parts you used?
07-28-2020, 08:48 AM | #6 |
I can't tell if your being sarcastic or not Herbie lol. @gwowzer are you referring to the sprocket? It's a JT back sprocket. If you do a little digging on Herbie's page you can find links to sprockets used. Also the method with the washer to offset the front sprocket an 1/8th of an inch. You have to do this or your chain is gonna be jumping on the rear or front sprocket. I wasn't sure where it was jumping. I just know it sounded horrible.
12-19-2020, 10:51 AM | #7 | |
Brozz Sprocket change
Can someone provide the link to Herbie's page. I'm looking for a smaller rear sprocket for the Brozz. Thanks, John |
03-21-2022, 08:15 PM | #8 |
I got REBEL GEARS tm, to make the correct offset sprocket with 42 teeth.
it cost three times the JT one but, I don't havr to shim anything. and its a perfect fit. DAVE |
03-22-2022, 10:17 AM | #9 |
I have run a 17/40 on my Hawk now for about 4000 miles and agree, it is indeed the perfect street gearing. I can purr along on the highway now at 6500-7000 RPM without any problems.
03-22-2022, 10:28 AM | #10 |
I'm going to suggest a cease and desist order for any power-up wheelies or clutch dump activities you may seek to engage in
03-22-2022, 02:05 PM | #11 |
Keep in mind that the Brozz uses a 17 inch wheel and tire combo out back, so with the same sprockets it is still effectively geared shorter than a Hawk by default. Any bike with that 17" rear wheel is effectively 3 teeth off of a Hawk (fewer), so a 40 rear sprocket on a Brozz is like a 43 rear sprocket on a Hawk. To match a Hawk with a 45 rear sprocket, a Brozz would need a 42. etc.
03-22-2022, 10:37 PM | #12 |
I put an 18T front on my brozz. It just barely clears. Then you don’t have to worry about alignment
03-23-2022, 08:15 AM | #13 |
Thanks Dan, I totally forgot about that.
