KPM 200 Windshield
Got my windshield in for the KPM. Didn't know if/how it would fit.
Well I think it fits perfect. Here is the link: https://www.ebay.com/itm/Smoke-Tinte...UAAOSwIiVe8Esr There were zero instructions so I just looked at the pictures. I added 3/8 foam at the bottom. Use some wd-40 on a cotton swab inside the grommets to help the fasteners slide in. |
Looks like a good fit to me.
Nice! Would like to see a side photo for perspective.
Looks awesome. Thanks for the info.
Question?
Have you noticed your headlight aims upwards? If it does, have you been able to fix it? |
Set the preload on your shock. If you're more than 130 lbs, the shock sags too much, causing your headlight to point up.
