Old 07-13-2020, 10:03 PM   #1
Ina Ditch   Ina Ditch is offline
Ina Ditch's Avatar
add on light options
I searched for a thread that I saw here awhile back and couldn't find it, someone posted some small led aux lights and if I recall correctly mounting brackets that fit the fork tubes. If this sounds familiar or you posted it I would love to know where to get them if the price point is what I remember.
Thanks in advance.
Old 07-14-2020, 11:51 AM   #2
Kenstogie   Kenstogie is offline
Kenstogie's Avatar
That's probably me....
Here ya go..... enjoy...
https://www.chinariders.net/showthread.php?t=26185
been around bikes for a while....
honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7
all about the Tao MotorsTBR7
http://www.chinariders.net/showthread.php?t=25553
Old 07-14-2020, 03:23 PM   #3
Deckard_Cain   Deckard_Cain is offline
Thanks in advance.
I mounted the exact same lights in the same location, except the brackets I made I used pieces of the metal shipping crate that the bike came in.
My brackets are too long though, they vibrate like hell when driving. I need to shorten them up and drill a new mounting hole/slot. I like using the bolt and welded nut that is on the metal brace, so it's easier for me to just re-do the top that mounts to the fork clamp.
Good lights though.
I installed a new main fuse block under the seat, ran my power to a relay and off to the switch on the handlebar, mounted in a housing that I 3D printed in ABS. Works awesome.
These lights put out a little more light than my LED headlight, so times two, angled off to the sides to fill in the dark spots, love it.
Old 07-14-2020, 07:07 PM   #4
Kenstogie's Avatar
I used 3 layers of aluminum 1/4 thick I think 3/4 total... and big bolts with lock washers and loctite...
Old 07-15-2020, 12:10 AM   #5
gwowzer   gwowzer is offline
Hey Ina..
So what I did on mine was the same Nilight lights, but I used the holes for the reflectors on the front fender. Just had to drill the plastic out the slightest bit to mount. Like barely drill to the point I could still remount the front fender reflectors if I didn't like the lights there.
It's really worked out well so far and I'm glad I did it that way. The front headlight sucks and I have performed the LED upgrade.
Old 07-15-2020, 12:19 AM   #6
Ina Ditch's Avatar
Thanks Ken, that is the tread that I was looking for !!
Old 07-15-2020, 12:25 AM   #7
Here are the same lights Ken linked to but mounted in the spot on the fender I was talking about. Should match up to your bike perfectly and save some money on the bar mounts.
Old 07-15-2020, 07:00 AM   #8
Kenstogie's Avatar
those look pretty sweet too...,
Old 07-15-2020, 08:04 AM   #9
Really nice job...closer to the ground as well for visibility
Old 07-15-2020, 08:58 AM   #10
SirKng   SirKng is offline
Slightly off topic but Kenstogie your TBR7 looks really good. I love how the bike looks without all the decals...
2018 SSR Motorsports XF250
Old 07-15-2020, 12:41 PM   #11
Kenstogie's Avatar
thanks brother!
my next step is to black out the tao motors on the motor....
heres an up close of the mounting bracket ....
Old 07-15-2020, 09:23 PM   #12
Ina Ditch's Avatar
Thanks G, I think I will try that mounting option and see how it works out for me.
your right, the stock head light is all but useless. it looks impressive when you look directly at it but a flashlight would be an upgrade as far as seeing where your going goes.
Old 07-15-2020, 10:28 PM   #13
One word of warning.. I did maybe not the smartest thing and wired the new lights into the high beam switch...
All is great while riding country roads at night and can see great.. then a car comes up and you switch to low beam.. you go from seeing everything to seeing nothing and a pretty scary feeling on a back road at night. I wish there was an upgrade to the headlight.
Old 07-16-2020, 07:37 AM   #14
An led H4 is world's better than OE... Drop one in and it's a significant improvement.
Old 07-16-2020, 11:36 AM   #15
I have the H4 installed. It's bright but the focus of the reflectors suck.
