Old 07-12-2020, 06:37 PM   #1
alex_in_az   alex_in_az is offline
better fuel petcock TBR7
I can't shut off the fuel supply at the petcock. it's supposed to be off with the lever in the horizontal position, but it still has a slow dribble. Does anyone know what the design was copied from or is there a more quality replacement part available? the thread looks to be M16 or 5/8"
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 07-12-2020, 07:53 PM   #2
Wild Dog   Wild Dog is offline
You need to replace it, i had the same issue, sometimes they fail and they keep sending fuel even if they are "closed".
Honda OEM part # 16950-krh-901
Originally Posted by jeffrey View Post
Take a look at a 1984 Honda XL250 petcock. I found one from walmart that had dimentions of the nut at 18X1mm inside and 24mm outside. Sorry no link to it.
Honda has a few petcocks that look the same, the 18x1 is the 16950-kpe-900 whcih is used for the XR 250, XL 250 and so on.
The Chinese CG use the petcock that was made for the nxr125 which is the 16950-krh-901 instead of M18x1 it is M17x1
But with the Chinese you never know... So if it is M17x1 it is the Honda part #16950-krh-901 but if it is M18x1 it is the #16950-kpe-900
