07-10-2020, 10:02 PM | #1 |
fuel usage
My back has healed enough that I was able to take a pretty long ride today and it was a blast except for one issue, at around 40 miles I had to detour to a paved county road to get fuel, I left the house with a full tank and it took 2 gallons to top it off so that means around 20 miles per gallon. the first 5 miles was run in 5th gear at about 50 mph, the balance was run in mostly 3rd and 4th at 20 to 30 mph, is this typical for these bikes? the bike is running great and performing like a champ so I am at a loss, my honda 300 four trax would run nearly non stop all day long on a tank riding the same places.
hauling fuel is an option that I don't look forward too but if this is normal I will have to get set up for it because getting to a fuel pump isn't always an option out here in hooterville. I should have mentioned that the bike is a 2020 Brozz Recon. Thanks folks. I.D. Last edited by Ina Ditch; 07-10-2020 at 10:03 PM. Reason: forgot to identify the machine |
07-10-2020, 11:18 PM | #3 |
I have no issues hitting 50+mpg at any speed. Float might be sticking, or the tank is leaking. Also check your oil level, if the floats stick it could be filling the crank case.
07-10-2020, 11:19 PM | #4 |
50+ mpg is what these engine do when they are stock and no power mods. So yes he may be uber rich or leaking fuel somewhere.
07-10-2020, 11:33 PM | #5 |
thanks for the quick responses. I have changed the oil 3 times in about 700 miles and there has been no fuel smell in the oil to this point but I will check that in the morning. I haven't seen or smelled fuel as if something is leaking but I will go over all that as well. the fuel cock was shut off last night, as a matter of fact I forgot to open it when I started it this morning and was surprised it wasn't running when I got back to it after running inside for my glasses. I'll check over all those points and also on my next ride I will note the exact mileage to come up with some accurate numbers instead of the estimated mileage.
Thanks again, it is much appreciated. |
07-12-2020, 08:22 AM | #6 | |
Something is definitely wrong, 20 mpg ? You’ve got a Gremlin somewhere.
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
07-12-2020, 08:18 PM | #7 |
20mpg is crazy low, even with all the mods I've done to my bike I would still get mid 60's mpg. Something is definitely wrong, I would check the plug to see if it's running rich if not I would be looking around for a leak somewhere.
07-12-2020, 08:38 PM | #8 |
Just throwing this out there... Was the tank actually full or were you just reading the gauge? My gauge reads pretty much full even though I've used maybe the top third of the tank up due to the way the float is calibrated.. stays on full forever, then from 3/4 to a little under a 1/4 it goes really fast, then stays at 1/4 forever.. in other words the way the tank float arm is set up it stays at it's fully extended positions much longer than through the middle of it's range.
07-13-2020, 09:23 AM | #9 |
I was also trying to check fuel economy on mine and found that it's hard to consistently fill the tank to the same point each time. This last time I let the attendant way over-fill it. Then I had fuel drooling out the cap and had to drain some out.
07-13-2020, 09:42 AM | #10 | |
To most accurate way to check the fuel economy is with the trip odometer, since the fuel gauge is not really that accurate. |
07-13-2020, 12:59 PM | #11 |
Even with all the mods done to mine and it tuned to run on the rich side, it still consistantly got 55mpg. You've got something wonky going on there.
07-13-2020, 01:11 PM | #12 |
my 1300 v-twin riding like an asshole still gets 30 lol.
07-13-2020, 08:53 PM | #13 | |
I did spend the time to check the oil and leak check and all looked good so I then jumped to the same conclusion. I am bad about leaving the fuel cock on so I was worried I was going to have gas in the crankcase. Thanks for all the info, it's in what's left of the old memory bank. |
07-13-2020, 09:08 PM | #14 | |
a days rest and I was good to go again, just got back from an evening ride. Oh, the road I washed out on is snake island road but it's more swamp than island most years. |
07-13-2020, 09:55 PM | #15 |
[QUOTE I washed out the front wheel trying to avoid finding the metal stays. I was able to step off but hurt my back again picking the bike up .[/QUOTE]
It could have been worse. At least you’re still riding!
