Old 07-04-2020, 10:04 PM   #1
Jo$h   Jo$h is offline
idle issue
Hey All,
New here but have a question...bought my son the Tao Tao 125 New Cheetah, has the FNR drive system, when I start it it idles extremely high, like full throttle high in Neutral. As soon as I shift into D the idle drops to normal, but then I can't get it to shift back into Neutral without killing the engine. Has anyone had an issue like this before. I've tried adjusting the carb...makes no difference at all. Wondering where to go next to try and take care of the issue. I'd send it back to the dealer but Im in Oregon and they're in Texas. So If I can get it fixed would rather just do it instead of going to all the hassle. Starting to wonder if it could be an electrical issue.. IDK...Thanks for any help.
Old 07-05-2020, 09:32 AM   #2
Merlin   Merlin is offline
I would look for a vacuum leak.
Bashan Blaze
Old 07-05-2020, 10:01 AM   #3
franque   franque is offline
Before looking for leaks - the choke isn't on, and the idle screw is correctly adjusted, right?
Old 07-05-2020, 10:27 AM   #4
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
Along with what franque says above, make sure the throttle slide isn't installed backwards in the carb throat and not closing all the way. The beveled edge of the slide goes to the rear (airbox) end of the carb.
Old 07-05-2020, 01:18 PM   #5
Will check those things. Thanks for the info. Hopefully it's one of those items.
Old 07-06-2020, 05:07 PM   #6
Vwchisme   Vwchisme is offline
What they said, something in the carb is causing it.
