Old 06-18-2020, 03:35 PM   #1
wamey   wamey is offline
wamey's Avatar
Doh! Swingarm Bolt
So my swingarm bolt head cracked off while riding forest roads over memorial day. Tried ordering from taotaopartsdirect.com but they hadn't shipped after 3 weeks so canceled that which leads me to info for you guys:
2017 Hawk
  • Thread Diameter - M14
  • Thread Pitch - 1.5mm
  • Thread Length - 30mm
  • Stock bolt shoulder length (including threaded end)- 255mm
  • Frame distance from bolt flange to bolt flange - 235mm
Here's what I sourced from Fastenal:
It cost $27.46 shipped to my local Fastenal store and gets there in 2 days. Kinda wished I hadn't been lazy and just did this the first time, missed out on 3ish weeks of riding...
Old 06-18-2020, 03:59 PM   #2
Wild Dog   Wild Dog is offline
2017 Hawk
Welcome to the club, there seems to be some swingarm bolts that are just cheap as fu..
I broke two until i found one that both ends were threaded, that one seems to be the best one.
Old 06-20-2020, 06:53 PM   #3
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
CSC TT250 Swingarm bolt is probably the easiest and best option. Just $6 and its actually an upgrade.
http://www.chinariders.net/showthread.php?t=24615
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
Old 06-23-2020, 10:20 AM   #4
wamey's Avatar
Here are pics of the Fastenal parts installed:
Old 06-23-2020, 03:21 PM   #5
Baskt_Case's Avatar
Is that a black oxide bolt? I would suggest perhaps hitting the ends with some spray paint or nail polish. Did you pack the tube with grease while you had the chance?
Old 06-23-2020, 03:43 PM   #6
Curious could you not source something similar locally from a LOWES or Home Depot ?
Old 06-23-2020, 04:03 PM   #7
wamey's Avatar
Yes and good idea! Noted about the grease, I'll do that this winter.
Old 06-23-2020, 04:05 PM   #8
wamey's Avatar
They're pretty tough to find in a brick and mortar store, kinda specialized
hawk, swingarm
