Old 06-16-2020, 09:36 PM   #1
vtwinaddicted   vtwinaddicted is offline
Doh! CG 230 cylinder head
Would a cg125 cylinder head work on my brozz 250?
Old 06-17-2020, 02:19 AM   #2
franque   franque is offline
The spacing for the cylinder studs should be different, I don't think it'll work. Where are you located?
Old 06-17-2020, 02:57 AM   #3
NzBrakelathes's Avatar
No
Old 06-17-2020, 07:51 AM   #4
Why a CG125 head? Why not buy the Brozz250 head?
https://shop.brozz250.com/eshopprod_...r_Assembly.htm
2004 Honda ST 1300
Old 06-17-2020, 09:07 AM   #5
Pennsylvania
Old 06-17-2020, 09:09 AM   #6
Combustion chamber size
Old 06-17-2020, 11:54 AM   #7
That's what welding is for! If you had a 200, it would work, they changed the stud spacing for the 230.
Old 06-17-2020, 02:04 PM   #8
Just mill the stock head down to increase the Compression Ratio.
2004 Honda ST 1300
Old 06-20-2020, 07:00 PM   #9
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
2 local shops quoted me less than $50 just to mill one down. And the Brozz (and TT250) head appears to have the best factory ports compared to all the others.
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
Old 06-20-2020, 08:04 PM   #10
Ultra budget compression increase, remove the cylinder base gasket and seal with a semi-hardening gasket maker. Just make sure to not block the oil passage to the head. Then replace the head gasket with a TT250 single layer steel unit.
Old 06-20-2020, 09:31 PM   #11
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
I took measurements with a straight edge and feeler guages then used a $25 handheld belt sander from harbor freight to deck my head. Just gotta keep rotating it with very light pressure to avoid removing metal from the wrong areas.
Old 06-22-2020, 06:10 PM   #12
CaesarVis   CaesarVis is offline
Does that give the same results as shaving?
Old 06-22-2020, 06:11 PM   #13
How much did you take off?
Old 06-23-2020, 08:43 AM   #14
Removing 1mm or 040" will bump you to 10:1 CR. You can easily remove that with sand paper on a flat piece of steel or glass. Lots of elbow grease and rotating the head every so often to make sure you are removing it evenly. I've done a few. A bench top belt sander will make quick work of it. That's what i used back in the day to shave down outboard heads for racing.
2004 Honda ST 1300
Old 06-24-2020, 02:43 AM   #15
How do you keep track of how much material needs to be removed and how much has been removed? That seems like it would be the trickiest part.
