Old 06-14-2020, 02:25 PM   #1
CaseysTech   CaseysTech is offline
2019 Lifan X-pect noise
Old 06-15-2020, 06:55 AM   #2
Jsalmi   Jsalmi is offline
Hello fellow Floridian, my X-pect has same noise if you' re referring to the gurgle (for lack of a better term). Sounds like intake noise that resonates at different levels at various rpms. Maybe the noise is even amplified inside the air filter box. Where about in FL are you? I'm in West Palm Beach
Old 06-15-2020, 02:12 PM   #3
Old 06-15-2020, 03:51 PM   #4
Look at the last post in this thread and see if you can move the tube in your tank.
http://chinariders.net/showthread.php?t=26591
Old 06-16-2020, 04:05 AM   #5
Ohh that noise... higher pitch fast vibration. Had that one too, and read replies here about tube inside the gas tank. Took a long screwdriver to move it gently to the left, its slightly back from the filler neck on the left side. Got rid of the noise
Old 06-16-2020, 01:41 PM   #6
Old 06-16-2020, 03:21 PM   #7
Old 06-16-2020, 08:42 PM   #8
Old 06-16-2020, 11:20 PM   #9
Originally Posted by CaseysTech View Post
OK I have checked valves for the 3rd time changed oil again. It is still there at 5k and up and only on throttle . It goes away as soon as I let any off the throttle.Everything is tight as far as I know. I had a Hawk 250 and had nothing like this. Bike has just over 200 miles.
Contact American Lifan and/or your dealer for diagnosis and warranty details.
Old 06-17-2020, 05:39 AM   #10
bored stiff   bored stiff is offline
ya I have the same noise, drives me nuts,You are right that it is only heard under load at higher rpm, ALMOST KILLED MYSELF TRYING DRIVE AND LOCATE, not good.Engine runs smooth,maybe in the gearbox. If anyone can run one of theses on a lift might be able to find it.Lets all keep on it, until together, we rid our society of this scourge! Or give up and accept it.
Old 06-24-2020, 02:50 PM   #11
Old 06-24-2020, 03:03 PM   #12
Old 06-25-2020, 05:38 AM   #13
I havent had time to address this on mine yet, but I will give it my full attention this weekend. My next step I was thinking of trying was lifting tank and placing foam tightly under tank to see if it deadens or changes the sound. this I think could at least confirm or rule out the tank as the source.
Old 07-02-2020, 08:24 AM   #14
Old 07-02-2020, 10:06 AM   #15
krat   krat is offline
I suspect chain tension is the problem. Your chain is slapping something when you are under load at specific RPM. it could be inside the front sprocket case or along the drive line.
Chain tension changes with load and speed and varies constantly while in operation.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
