Congrats on the new bike. Always a great feeling.
Congrats! You're going to really like it. So is yours one from the new shipment? I know Venom was trying to get them with a smaller rear sprocket and hopefully they got the speedometer calibrated a little better.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-09-2020 at 04:47 PM. |
Here she is. I have to say this bike has already exceeded my expectations. The quality of this machine is so much better than my last China bike. Didn’t get a chance to star it yet but definitely will tomorrow. Still has a 42 tooth rear sprocket so I am guessing nothing got changed on this batch.
I can’t get the picture to post right
It's an Aussie bike. Happens all the time.
I just noticed some differences on the engine. Has different covers on both sides of the engine. There is no oil sight glass and it appears to have a little different clutch cable assembly.
#9 | |
#11 |
Those few little mods will make you like it more. The sprocket change alone will make the bike feel much better.
#12 |
I also was extremely impressed with the quality of the bike compared to my expectations.
Use some brake cleaner on the rotors if you haven’t. They come shipped with oil on them and it takes a few hundred miles to wear off naturally, but the brakes work much better once it’s off. Also, I bled the brakes and added better brake fluid which also helped. Now the brakes bite very nicely. Yes, the pod air filter, cat removal, jetting, and sprocket change really really improve the bike. Also, it’ll gain more power as it breaks in. It really is a fun bike. The only real negative at this point on mine is the battery was pretty cheap and after sitting due to rain for a week it was dead. This happened twice so I replaced it and I hope I have more luck with this one. Otherwise, the bike has greatly exceeded my expectations.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
#13 |
I have been so busy with work I have only got to ride maybe 4-5 times. I did however install a k&n pod filter and re jet to a 108 main and drilled the plug out of the air/fuel screw. Jetting makes such a difference. I am still only hitting around 60mph top speed. I ordered a 36 tooth rear sprocket last night and hope to gut the cat sometime this next week. I am looking at bigger engine mods and ran across a big bore kit on eBay that comes with cylinder, piston, cam and rocker arms for 169.00. It’s a Chinese kit. Does anyone have any experience with Chinese big bore kits? Is it something to avoid? I can’t find any Athena kits anywhere right now. Link to the kit below.
https://www.ebay.com/itm/67mm-235cc-...EAAOSwtzle7dwu |
#15 | |
