Old 06-06-2020, 01:10 PM   #1
Vwchisme   Vwchisme is offline
Chain Tention
Having issues with the chain coming off. I've been tighten by putting an old Philips in the hole and using leverage, busted my knuckles. There got to be a easier way right?
[IMG]Gy6 utility ATV by ntrodriguez, on Flickr[/IMG]
Old 06-06-2020, 03:06 PM   #2
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
How about a big long tapered drift punch, so it seats itself in the hole?
Old 06-06-2020, 06:42 PM   #3
chain adjusting
see this
ABIBABA ATV ETC
Old 06-06-2020, 10:16 PM   #4
Originally Posted by FLASHLIGHTBOY View Post
see this
Don't have them holes on the side
Old 06-06-2020, 10:19 PM   #5
For some reason wasn't as hard this time around. Replaced the studs and nuts with grade 8, see what happens.
[IMG]ATV rear tension by ntrodriguez, on Flickr[/IMG]
Old 06-07-2020, 04:51 PM   #6
franque   franque is offline
You can grease/clean the surfaces that rotate when tensioning the chain, that'll help.
Old 06-08-2020, 07:24 PM   #7
The change in bolts seems to be holding, no dropped chain on yesterday ride.
Old 06-16-2020, 10:45 AM   #8
VeeVee   VeeVee is offline
VeeVee's Avatar
On a Rhino 250, how do you loosen or tighten the front two nuts on the adjustment. I do not have a tool that I can get on them, no room. I just ordered a crows foot open ended wrench set. Hope this works. What do you guys use? My new chain now needs tightening.
2020 Toa Motor Rhino 250, two inch Rear wheel spacers, NGK Spark plug, More upgrades to come!
Old 06-23-2020, 02:45 AM   #9
IIRC for the Rhino style tension screws. I had to remove a couple of the bolts that hold the rear end to the frame. Then i was able to get a wrench to fit, its been a while since i done it.
Old 06-23-2020, 02:45 PM   #10
VeeVee's Avatar
Vm, The crow's foot was the deal. Got a set on Amazon and was in my hand in two days. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Made it into a pie job! Never had a set till now. Problem solved.
Old 06-23-2020, 03:52 PM   #11
crabjoe   crabjoe is offline
Good to know what to use. I've got a set but I've never used them. Whenever I go to HF, I have this habit of picking up tools I don't have, just in case I might need them down the road. That is if they're cheap enough.
