Old 06-01-2020, 11:25 PM   #1
Kimberly   Kimberly is offline
Head Scratching Parts compatibility for Hellcat 125
Is this the right place to ask these questions?
I am wanting to change a few things on my bike. I need help. I have the 2019 TaoTao Hellcat 125. I want to put different mirrors on. Like the handlebar end style. Are those standard 7/8"? Use the same as the Grom? Same question with the shift levers on both clutch and brake. Want to put in short shifters. It's impossible to find aftermarket parts for this bike. Help!
Old 06-02-2020, 12:07 AM   #2
deadwood83   deadwood83 is offline
deadwood83's Avatar
The parts you listed should be fine.
Levers: Grom
Bar end mirrors - 7/8" bars
Here are the areas where the bike differs from the grom:
Internals of the forks.
Steering stem / triple bearings
Electronics (some wiring can be adapted for lights and signals)
Motor mods. Look at pit bike mods, not grom mods for motor related items.
Chain is a 428 size while grom is a 420.
Rear shock / battery. Any grom shock without a reservoir will fit. Any shock with a reservoir will require the battery tray plastic piece from a grom as well as a grom battery.
No EFI on the hellcat so obviously ecu tuning is out of the question.
Notes on compatibility:
If you get a grom body, you may need some of the under plastics (black) in addition to the colored pieces.
Grom body and seat to fit the Hellcat is the OG model (2013 to 2015)
Old 06-02-2020, 06:18 PM   #3
Thank you very much. This little bike is a bit of a challenge.
Old 06-02-2020, 11:38 PM   #4
One more question. You're very kind to help me with this. The clutch foot pedal/lever. Would the Grom be compatible?
Old 06-03-2020, 09:14 AM   #5
Deckard_Cain   Deckard_Cain is offline
Honda 125cc pit bike parts would be a closer match. You will probably want to compare measurements of your OE levers to that of any replacements you're looking at.
Old 06-03-2020, 01:34 PM   #6
scoot newb   scoot newb is offline
scoot newb's Avatar
These levers will work with the stock perches.
https://www.amazon.com/gp/product/B07SW4GXTN
This shift lever works.
https://www.amazon.com/gp/product/B01H8N7YLY
Old 06-03-2020, 07:37 PM   #7
Perfect. Thank you!!!
