Old 05-23-2020, 07:28 PM   #1
harmon   harmon is offline
greetings from canada
After riding on the street for many years, I sold my beloved Buell S 1, and decided to ride in the dirt. Bought a sadly neglected 2011 Gio. It is basically sound just needs some TLC. Looking for a clutch cable from Canada (border is closed) No luck so far. Does anyone know where I can buy one? Thanks in advance, Harmon.
Old 05-23-2020, 08:11 PM   #2
I'm not Canadian, but if you can get your hands on a Venhill kit you could always build your own. Just need to be able to solder one of the ends on. Kit U01-1-100-BK should do the trick.
Otherwise, you could give Venom Motorsports a call as they are based on both sides of the border. They might be able to help sort you out with a clutch cable that would work.
Old 05-24-2020, 06:27 PM   #3
gio clutch cable
Thanks Megadan, I'll look into it.
Old 05-24-2020, 07:25 PM   #4
Bruces   Bruces is offline
You can also try member flashlightboy ,as he is a dealer for Gio .
Old 05-27-2020, 08:46 PM   #5
Welcome!
