Old 05-23-2020, 04:17 PM   #1
Brozz250welder   Brozz250welder is offline
Need a legitimate jet kit for 2020 brozz 250 please
Ordered a kit on Amazon it just arrived. $39.95 it included a 107.5 a 112.5 a 38 a few washers a wood screw and a drill bit. Pretty pissed the bike already has a 105 those are useless. Any suggestions or insite as to why I got a a countersunk wood screw? Also a link with a real assortment of jets. Amazon link? I would appreciate it. Thank you is the carb a keihin pe 30?
Old 05-23-2020, 04:28 PM   #2
Old 05-23-2020, 05:06 PM   #3
mtiberio   mtiberio is offline
mtiberio's Avatar
https://sites.google.com/site/motocheez/brozz-250
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami
Old 05-23-2020, 06:47 PM   #4
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
That kit looks like its for tuning a stock Hawk carb. Hawks come with tamper proof bowl screws, a rubber plug over the fuel screw, a needle without clip slots, and a weird pilot jet.
If you dont know what carb you have, we need a picture of both sides. Is it the carb that came with your bike? If its the factory carb, its definitely not a PE30. They are often a "sealed" PZ30 but you said you've already been inside the carb.
www.jetsrus.com can help you identify your jets
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
Old 05-24-2020, 02:27 AM   #5
NzBrakelathes's Avatar
That’s an expensive kit but looks right
1 pilot several main jets
Old 05-24-2020, 08:46 AM   #6
Thanks guys. Yea I thought it was going to be a very complete and extensive kit. I dont know what carb,
The bike is arriving Tuesday. I just want to have something on hand to tune it if necessary.
Old 05-25-2020, 09:04 AM   #7
KseKermit   KseKermit is offline
Yep link mtiberio sent is what you need. I actually over drilled my main, got a piece of copper wire macgyvered in there to restrict flow until my kit comes in.
