05-21-2020, 01:56 AM | #1 |
2009 gio. X31? Zongshen motor?
Okay, so here's the down low.
Picked this bike up from a friend's in law for a bottle of rye. He said it's a 250. Supposedly he's done the top end of the motor, gotten to the timing, and given up. Its obviously been dismantled, including the head. After a few quick looks, I already had more questions than answers. I'm totally new to the gio's. But I have done timing chains on a few other ohc engines. Looking at the flywheel through my site hole, I cant find any markings as to where tdc or bdc is. Same with the cam, no markings there either. I would love to be able to identify what kind of bike I have, hopefully get my hands on a service manual. Or what engine it was modeled after. Essentially all you do is find tdc on compression stroke and set valve clearance to 4 thou exhaust, 3 thou intake? I can tell already this community is an extremely knowledgable one, and I look forward to joining in on it. Thanks for the time. |
05-21-2020, 02:20 AM | #2 |
Welcome! Do you have the top cover that goes with the engine? It seems like a nice buy, but you'll need that. The XR200 manual should help with engine assembly, but like you were saying, it might be hard to properly assemble without markings.
Are you sure that there's no markings on the cam gear (could be on the other side of the gear, if it was put on backwards) or flywheel? You might need a flashlight to see them, you're looking for a |T or |F mark. You might also need to remove the timing cover, because sometimes they're marked on top of the flywheel. |
05-21-2020, 02:24 AM | #3 |
Yup, I've got the valve cover. I just took it off to get a look at the cam/valves.
To be honest I didnt check the back side of the cam, that's a great idea. I had my flash light in the flywheel site hole looking for the T or F but to no avail. I'll check behind the timing cover next and the back side of the cam. |
05-21-2020, 03:47 PM | #4 |
So I found the engine code.
I guess next ill pull the flywheel cover off and look for alignment marks. Does anyone know where the cam lobes should be orientated prior to me putting the valve cover back on? With no markings on the cam, I'm kinda shooting in the dark. |
05-21-2020, 04:15 PM | #5 |
Sprocket bolts should be vertical and lobs facing down @ TDC
05-21-2020, 04:38 PM | #6 |
It's not really a valve cover per se, and in some ways, it's best not to think of it that way, because removing it is almost always unnecessary, and you need to reseal it with a thin coating of Honda/Yamabond so it won't leak, as it doesn't have a gasket. Make sure that you get not surfaces clean with a razor blade, too. Best of luck, we're happy to help!
05-21-2020, 07:51 PM | #8 |
I saw on an Ebay add for the same motor this statement. Is anyone able to confirm?
Suitability: Direct replacement for Orion Apollo AGB30, 31 and Hummer range All Atomik 250cc air cooled Bikes and all Crossfire 250cc air cooled bikes. If this is true, does anyone have service manual for any of those engines? I couldnt find them on the google. I'm looking specifically for valve clearances now. |
05-22-2020, 02:21 AM | #9 |
https://www.motorfans.com.cn/forum.p...=343764&page=1 (needs change to desktop mode if view from mobile device) had some pics rebuild vertical Chonda ohc engine.
=== Most "69" are lies. 65.5mm is the answer... Just find a Honda shop manual (63.5*62.2 XLR200R https://www.4shared.com/office/xZy8oNOV/ ... | 65.5*62.2: CRF230) in 'net & call it a win since u had experince working on ohc machine.
05-22-2020, 06:09 AM | #10 |
Looking at it again, I would consider disassembling the motor to remove all of the red silicone, it's not good for the life of a motor, it has a tendency to clog up oil pumps/ruin bearings. I would check the bore, as alluded to above by humanbeing, and order a corresponding gasket set. If you need part numbers, I can get you Honda ones.
06-18-2020, 10:02 PM | #11 |
Take the stator cover off. And the flywheel will have marks, you just can't see them through the sight hole that's in the cover itself. Then you'll be able to find TDC. And then line the cam up so the bolt holes are vertical with the cylinder. One line of the cam sprocket should line up with the top of the cylinder.
