05-19-2020, 10:58 PM | #1 |
Just purchased a Coolster 3150DX-4... Have a few questions...
I just purchased and received a Coolster 3150DX-4 ATV, and I have a few questions.
1. The front shocks are horrible! I'm 300lbs and 6'5" and even I can't get them to even move!!! The rear shock is fine, but the fronts are so stiff! What size shocks do I need? Any recommendations? 2. Can I get a link to wheel spacers that will fit this model? 3. The steering is very stiff, is there a way to fix this? 4. The font brakes are horrible! They are cable style brakes... Are there any mods or upgrades available? 5. There is a lot of vibration when driving. What can I do for this? |
05-20-2020, 08:11 AM | #2 |
Welcome aboard!
1.Front & rear shocks will loosen up. They are stiff at first. 2.Wheel spacers for honda 4x110 lug pattern will work. Plenty to choose from on ebay and amazon. https://www.ebay.com/sch/i.html?_fro...acers&_sacat=0 3.Use a spray lubricant on the steering. These bike come with very little grease on anything. I installed grease zerks on all the pivot joints. 4.Front brakes aren't the greatest. Use cable lube on the cables will help improve. 5.The engine will smooth out after the engine breaks in. Check all your engine mount bolts to make sure they are tight or not broken. One loose or broken bolt will make it vibrate more than normal.
05-21-2020, 07:33 AM | #3 |
Can you recommend any upgrades or modifications?
