Old 05-15-2020, 05:51 AM   #1
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
Offset Flywheel Key - Timing Advance
I've found a guy making 2 and 4 degree advance offset keys for the flywheel on an Orion OHC CB.
Does anyone have specs or measurements for the keyway and key on a CG?
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
Old 05-15-2020, 06:58 AM   #2
franque   franque is offline
It's probably the same, if I were you, I'd order it and see if it works.
