Old 05-14-2020, 11:20 AM   #1
Redex00   Redex00 is offline
Speedo stopped working suddenly
So i was riding and my digital speedometer just went blank. The other instruments are still working fine. I don't know where to start looking. Can someone help?
Old 05-14-2020, 12:45 PM   #2
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Does the backlight still work and just says 0 MPH? If so I would check the speed sensor on the front hub and the wires from the hub to the display. If the backlight isn't working then I'd check that the display still gets power. It might be a loose connection at the battery or at the connector also check for a blown fuse.
Electrician & Electronics Tech
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 05-14-2020, 01:29 PM   #3
Ya it just says 0mph. I noticed a wire hanging from by the front tire and I think i see where it goes but it just kinda falls back out. I'll try to post a picture when I get out of work. Thanks.
Old 05-14-2020, 03:12 PM   #4
https://drive.google.com/file/d/1XqI...w?usp=drivesdk
I hope I shared them correctly.
Old 05-14-2020, 03:14 PM   #5
https://drive.google.com/file/d/1XvT...w?usp=drivesdk
Old 05-14-2020, 03:20 PM   #6
I'm gonna quit while I'm ahead at this uploading images game. Anyway that's the part that was hanging so I only assume it's the Speedo cable. Does it need an adhesive to stay in the hole? It's all greased up if that helps.
Old 05-14-2020, 03:52 PM   #7
https://drive.google.com/file/d/1Xw4...w?usp=drivesdk
Old 05-14-2020, 04:17 PM   #8
New development*. I noticed the hole has a threaded hole and the hanging wire has a screw hole. I think I just have to figure out what screw I need. Is there supposed to be some indication of it going in the hole because it just seems to "sit" in the hole?
Old 05-14-2020, 05:06 PM   #9
duck9191   duck9191 is offline
The last link works to the picture, looks like it pulled apart. what does the cable end look like?
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 05-14-2020, 07:11 PM   #10
Okay. Seems like it did pull apart so I'll need a new cable. Doesn't seem too bad as long as I can find one.
Old 05-14-2020, 07:13 PM   #11
should be able to find one, what bike is it?
Old 05-14-2020, 09:03 PM   #12
It's a boom 125-11. I was hoping the place I bought it from could help but they're slow to respond.
Old 05-14-2020, 09:12 PM   #13
I'm pretty sure all the Chinese Grom clones use the same generic front wheel speed sensor set up, parts kit.com has what you need for $12, here is a link to it, its also item #12
https://partskit.com/product/search/...ering%20System
It's for a TaoTao HellKat but i have a 2018 Vader and it looks just like mine so it should work , you can try calling Kronik Racing in Cali tho if you want to see if they might have one from BOOM / Baodiao.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 05-15-2020, 11:54 AM   #14
Thanks for the help. Oh, and does is it still considered a grom clone if it looks more like a ninja clone?
Old 05-15-2020, 01:45 PM   #15
if it's the "full size" Boom 125 then there is a possibility the cable wont be long enough , those are taller than the Vader or HellKat , but you could always splice the wires into your old one, and use the new sensor. That partskit site might have a "fiull size" pitbike with a cable that would work though, i dont really keep up with stuff that isnt the grom clone or the " lil duc" style clone.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
