05-14-2020, 01:04 AM | #1 |
Falcon 250cc
Can anyone help i got a falcon 250cc automatic and i assembled it but it won't start the lights are on but won't start
05-14-2020, 08:04 AM | #2 |
when you say won't start, do you mean the starter won't turn are as in the engine will crank and won't run? If the starter won't turn make sure that you have it in neutral and/or clutch pulled. some bikes have a safety switch on the kick stand so the the kick stand has to be up in order to start. Some bike require the brake to be applied to start.
If it cranks but not start, make sure that the kill switch is not on.
05-14-2020, 01:22 PM | #3 | |
05-14-2020, 01:26 PM | #4 |
I knew that, What was i thinking. lol Make sure the battery is fully charged. More than likely you will have to apply the right brake lever and possibly have the kick stand up if it has a safety switch.
05-20-2020, 02:45 PM | #5 |
Hey thanks i found problem the cable on handle bar power switch was unplugged lol
