Old 05-07-2020, 08:23 AM   #1
Dbrown672   Dbrown672 is offline
2018 Brozz 250 Vibrating Mirrors
Hello everyone,
I have a Brozz 250. When I get up to about 30+mph, my mirrors vibrate a lot and it makes them almost impossible to see in
Has anyone had this issue and found a solution? Thanks!
Old 05-07-2020, 08:52 AM   #2
mtiberio   mtiberio is offline
mtiberio's Avatar
On my '18 which I owned for 8 days, I noticed one side would do that, the other, not. YMMV.
Solution? tighten up mirror to stank pivot. Replace. Bird shot in bars?
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami
Old 05-07-2020, 11:38 AM   #3
I've changed my mirrors out for these on all my bikes. Cheap and don't really buzz.
How many miles on the Brozz? Is it broke in yet? It will smooth out a lot when the miles tack on.
Old 05-07-2020, 11:45 AM   #4
herbie   herbie is offline
My 2018 Brozz was smooth right out of the box, no issues with mirrors vibrating. Is your bike stock or have you modded it?
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 05-25-2020, 11:10 AM   #5
Thanks for the replies guys. I tried tightening them up and it helped a bit. Yes, you are right one side vibrates more than the other. I realized it is when I get the RPM's over 4-5k is when they start vibrating a lot. There is just over 300 miles on the bike now so still pretty new and not broken in fully
Old 05-25-2020, 01:10 PM   #6
paulsstag   paulsstag is offline
2LZ is correct. My TBR had 1X goog mirror and 1X not so good as it vibrated bad even after i tightened the screw at the top of the stalk.
I replaced my mirrors with the set that 2LZ mentioned and they are like night and day, the stalks are even thicker and they stay put even off road.
Another benefit is they are slightly wider and i can see past my shoulders much better than the stock mirrors.
When i bought the new Brozz Recon i had already ordered a new set and did not even bother with the originals which are still wrapped up from new.
Old 05-25-2020, 01:16 PM   #7
The funny thing is, I just got used to looking in vibrating mirrors. I only use the mirror for quick checks, so detail isn't important as just seeing. I do more head checks than I do mirror checks.
As the others have mentioned, I used the same mirrors that 2lz posted on my last hawk after I busted my stock pair. They do work really well.
I am more amazed that your Brozz has that level of vibration from the engine. Sounds more like a problem one of us unbalanced engine guys would have.
Old 05-28-2020, 08:33 AM   #8
I ordered those mirrors from Amazon, will let you guys know how they work! I’ve also gotten pretty good at using the vibrating mirrors haha
The vibration isn’t outrageous to me, but then again, this is the first bike I’ve had. Mtiberio might be able to weigh in on this since he has driven the bike. He would have more to compare it to
Old 05-28-2020, 03:22 PM   #9
Ina Ditch   Ina Ditch is offline
Ina Ditch's Avatar
I haven't had vibration issues with mine but I don't really care much for them.
brozz 250
