Brozz rear shock
I have searched in vain for the length of the stock shock on the brozz 250 and recon and came up empty, anyone know off the top of your head?
#2 | |
#3 | |
Maybe one of the owners or Jeff will add that info. ![]() |
#5 | |
![]() you got me by an inch Dag. I have made up my mind to quit looking at seat height and just pay the price of lowering whatever bike that I end up with. I have watched countless videos and read even more threads and I am convinced that it can be done without ruining the handling, like everything else it = time and money. If you lower yours I would love to read of your experience. thanks again. |
I measured mine and its around 300mm like 11-inch.
On the radar: CSC - TT250 Moto Aventure ride 2020. "If everyone is thinking the same thing, no one is thinking." Gen. Patton. -2017 Suzuki SV650 -2015 BASHAN - STORM Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black. -2005 Skyteam ST90 (sitting in pieces) -2003 Buell Blast - SOLD |
Thanks SkyTeam.
Following. I am planning to give my Brozz to my son and he is on the shorter size. I shaved the seat but may need to adjust suspension.
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
I don't know that I am the guy to take any advice from but I have a shock ordered and should have it in a week or so and I am eager to get to it. I have found a few places with good video and or direction on lowering the front forks and I am going to attempt that as well in an attempt to keep everything as evenly dropped from front to rear as possible. I will share the experience here but there are far more experienced folks who have tutorials already available. Oh, I will try slipping the forks in the clamps before busting into the cylinders.
#10 |
I stumbled upon this finding the shock length for the brozz again and thought I would update it for the benefit of not-tall folks looking at it as an option.
I am 5'6" tall and go back and forth between 165 and 170 LBS, I don't know my actual measured inseam but I wear 29 and 30 inseam jeans. when I first got the brozz ( RECON ) assembled I was on the balls of both feet holding it up, I don't know if the spring collapses quickly or what but within a couple of hundred miles I could flat foot it. the rear suspension is pretty soft for off roading so I am going to buy the same length shock but at a higher quality with a 1000 LB load rating. |
