Old 05-03-2020, 06:12 PM   #1
Kenstogie   Kenstogie is offline
Kenstogie's Avatar
aux Light install and redid all graphics
installed the aux lights was only about 50 beans total and is really necessary if you want to ride at night....very bright i think
LED lights
https://www.amazon.com/Nilight-Drivi.../dp/B00G620ZVU
relay wiring kit
https://www.amazon.com/Nilight-10007.../dp/B073XMM3T5
bar mounts
https://www.amazon.com/LAMPHUS-Off-R.../dp/B0791NB4FM
switch
https://www.amazon.com/Motorcycle-Wa.../dp/B07JKPRWMK
the relay nestles in under the seat nicely, and to clear the fairings i built a small bracket out of bar aluminum....all the wires ran under the seat where all the other ones are..... probably took 4 hours or soo... the brackets needed about 7 wraps of electrical tape to make them fit perfectly
also removed and redid with custom decals.... me and my wrench turning friends were over and we all agreed the stock decals make it look like a toy and looks waaaaaay better removed and redone.....
been around bikes for a while....
honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7
all about the Tao MotorsTBR7
http://www.chinariders.net/showthread.php?t=25553
Old 05-03-2020, 07:16 PM   #2
Kenny,
Could not agree more with removing the decals, my son called my bike "the transformer" so I went with the naked option, your simple graphics look great.
The aux lights are sick, but to be honest, you should replace the stock light with LED so they match
Is there an LED bulb option for the stock bulb ?
Nicely done!
Old 05-03-2020, 07:28 PM   #3
Kenstogie's Avatar
Originally Posted by kingofqueenz View Post
Kenny,
Nicely done!
thanks ! the naked option looks better in person than in the pics, i think.
totally agree about swapping the headlight but
i am not aware of a replacement....
Old 05-04-2020, 02:27 AM   #4
Interesting mount choice, but it works well. No issues with hitting the tank plastics?
How do you like those lights. The cheap round spots I initially installed on my Hawk have dimmed a lot very quickly so I am looking to replace them. If I can manage to bring myself to spend the money on them, I really want to mount a set of Rigid Ignite lights to my forks, one Spot, one flood. They are worth the money, insanely bright and very small, but at almost $70 each.... owie lol.
More than likely I am going to step up to a pair of these with the 60 degree spread as a compromise in width and distance. https://www.superbrightleds.com/more...ns/1699/12999/
Old 05-04-2020, 08:15 AM   #5
Kenstogie's Avatar
no problems with the plastics but did have to build a small bracket lowering them.... they are blueish light ( not a huge fan of ) but they do light up the trail well and considering the price are a win. sometimes you get lucky with inexpensive stuff sometimes you have to spend the coin....
Old 05-04-2020, 08:26 AM   #6
Kenstogie's Avatar
..... also did my first oil change at 70 miles. i expected it to be more cruddy and black but not that bad, i did find a 5 or so small pieces of metal flakes/ crumbs on the magnetic drainplug, but that doesn't bother me i am pretty sure thats normal breakin stuff..... actually it was the second oil change as i never ran it with the stock oil.
Old 05-05-2020, 11:48 AM   #7
Goob   Goob is offline
Superbrightled
Those are the spots I would have gotten if I had a few more bucks. I got their 800 Lumen/11W ones cause they were about 1/2 the price; 60 degree. They are pretty good, but not as much throw as I expected. Think I will likely get the brighter ones you listed next time (maybe when I get my next bike).
CSC TT250
Orion RXB 150XL
Old 05-05-2020, 11:51 AM   #8
Saved your selection..
LED lights
relay wiring kit
bar mounts
switch
Thanks. Nice selection of parts. I especially like the relay package. I didn't find the need for a relay on my bike, but good to know. I saved all the links for the future.
CSC TT250
Orion RXB 150XL
Old 05-05-2020, 12:38 PM   #9
Kenstogie's Avatar
not a super high drain set of lights but for me as a general rule i run my aux lights on a relay always.... i dont want alot of electricity run through a feeble switch....
Old 05-05-2020, 06:49 PM   #10
Kenstogie's Avatar
Heres a couple more that you really couldnt see above
Old 05-05-2020, 08:32 PM   #11
CHONDA sticker is classic... nicely done
Old 05-05-2020, 11:29 PM   #12
No switch...on all of the time
I didn't use a switch, as I wanted them on anytime the ignition is on...just like the headlight. More light to be seen during the day (by cars) and more light for my AM ride. Good all around.
My first set were 20W (supposedly 1600 Lumens) each, meaning only 3.33 Amps draw. Had no issues. Went smaller on the 2nd set (just what I found at the right price and better quality). These are 11W (800 Lumens) so only 1.83 Amps draw. Nothing.
CSC TT250
Orion RXB 150XL
Old 05-05-2020, 11:29 PM   #13
Ninjaguy23   Ninjaguy23 is offline
Ninjaguy23's Avatar
I’m digging the CHONDA” sticker too!! ����
