Noticeable improvement
Just got back from a test ride with the new ported and decked head. It does stupid easy rolling wheelies in 1st and just gets the wheel up in 2nd. I did a sped run on the freeway and it got to 71, up from a previous high of 65. I was at about 8k in top and the bike was missing at wot, maybe going up from a 115 main will get me through the miss fire?
Yes, you will need to bump up the main jet size quite a bit after porting the head. I don't know how aggressive your port work is, but I would say at least a 125 to 130 main to start. My Hawk is on a 135 main with the PE30 carb.
I agree. At least a 125 main. Welcome to da club.
I took a lot of material out of the exhaust port on the top side of the runner and around the valve guide area. I took some from the intake port and removed the part lines on the port sides
did you find any tutorials or video of this?... for those of us that kinda understand but would like to see if its a feasible for us?
nice work though ![]()
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
there's a couple of threads on this site on how to do it, mostly it's the exhaust port that needs work and take .040 off the head to raise the CR
Between Megadan and I we both have thread on it.
#8 | |
this is good thread on it...l
