Old 05-02-2020, 02:52 PM   #1
alex_in_az   alex_in_az is offline
229 engine head bolt torque?
What should the bolts be torqued to? I'm going to replace the stock head with decked ported one
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 05-02-2020, 04:06 PM   #2
Mudflap   Mudflap is offline
They're actually nuts. Honda CG service manual says 24 foot pounds.
Old 05-02-2020, 04:27 PM   #3
Thanks, is the manual online anywhere?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 05-02-2020, 04:31 PM   #4
Yep 24ft-lbs will do you fine (that's about 18 gutentights). the outer head bolt on the left side is a little lower, 20lb-ft I believe. Some later CG engine manuals bumped it up to 28, which is what I used for mine since I raised the compression, but 24 will suffice.
Just do the main 4 in a criss cross in at least two stages. I did 15lb-ft for my first set. Once those 4 are done, do the outer bolt.
Old 05-02-2020, 05:31 PM   #5
humanbeing's Avatar
Originally Posted by alex_in_az View Post
...is the manual online anywhere?
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
Old 05-03-2020, 07:19 AM   #6
NzBrakelathes's Avatar
20 thou 0.50mm over size
For all it’s worth etc
File Type: jpg 7A8F4519-34CD-4F58-B0BC-748B4C0377C2.jpg (12.3 KB, 996 views)
Old 05-06-2020, 01:00 PM   #7
Sochin   Sochin is offline
Sochin's Avatar
Here I've been told 1 gutentight is until it strips then one additional half turn
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
