Old 05-01-2020, 11:47 PM   #1
mBuxx   mBuxx is offline
Venom Grizzly 125 stuck float?
Hello, I have a few venom grizzly 125’s and one of them has a stuck float, causing fuel to drain out the over flow. My problem is the float bowl does not come apart?! I have put it in the ultrasonic anyhow but still no luck. Are there any replacement rebuildable carbs for these things?
It’s a Jingke PZ20
Old 05-02-2020, 06:25 AM   #2
Al   Al is offline
eBay or Amazon or just Search Google. Search pz20.
Old 05-02-2020, 09:24 AM   #3
I don’t want the same carb though, if that makes sense . I want to be able to just rebuild it from now on.
Old 05-02-2020, 09:55 AM   #4
gipetto   gipetto is offline
I think you are mistaken. the bowl must separate, otherwise it could not have been manufactured with a plastic float inside.
Old 05-02-2020, 10:25 AM   #5
It’s secured with tamper proof screws. When it was manufactured the bolt heads snap off when they are inserted. I’m assuming this is some EPA thing to keep people from messing with the jets and stuff.
I suppose I could use a screw extractor, and replace them with normal ones.
Old 05-02-2020, 10:36 AM   #6
Rob G   Rob G is offline
Rob G's Avatar
I use a dremel tool with a cutoff wheel to cut a notch in the float bowl screws, then use a flathead screwdriver to remove them. Replace them with new screws. Then use a drill and drill a hole in the little plug coving the mixture screw and pull it out.
"If money is your hope for independence, you'll never have it. The only real security that a man will have in this world is a reserve of knowledge, experience, and ability." Henry Ford.
2018 Tao Bull 200 red
2018 Tao Bull 200 green
2018 Tao New T-Force graffiti
2018 Tao New T-Force blue
Old 05-02-2020, 11:59 AM   #7
That’s a great idea, thank you. You don’t happen to know the replacement screw size do you?
