Cg250 Flywheel threads.
I have been searching for a while to find this answer with not much luck. I need the thread size for the flywheel puller. From what I could find I believe it is an M27 left hand thread, but if anybody can tell me for sure I would appreciate it.
Ok, so it is an M27x1. I will order this puller as it appears to be the same as what you linked. https://www.ebay.com/itm/1pc-Black-M...-/352663054759 Thanks for the response!
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 04-26-2020 at 08:59 PM. Reason: 8 |
That's what I wanted to hear. Thank you sir.
So does this mean the cam swap is about to began??
I do plan on doing the cam swap here soon. I figure it is worth a go before I decide to just move on. I have other more useful plans for the money I would be spending on the GTO, so I may just hold off.
In order to get the cam pin out the flywheel most likely has to be removed. If not, great, I still want the tool anyway.
