Hi all, I lowered my tbr7 and my stand wound up to long, I chopped 2 inches
Out it and rewelded it, bike now leans on stand just right. Anyone looking to Lower you bike (I'm 5/7) like the amount I did 2 inches seems to be perfect! Also does anybody know of a good,small tachometer I can mount on my bike Handlebars,or dash? I checked AMAZON, there either too big, to many bad Reviews,or too expensive Thanks all Christopher |
What did you do to lower it? I'm considering this as ok like 5ft5 or 5ft6 I dont really remember ive been saying 5ft6 for so long but not sure if its really true haha.
Rear shock is adjustable and lower the front forks
Hi fadeyt I forgot to write that I removed a 2 inch section of the kickstand. The bike now
Leans at almost the perfect angel. I cut it, then I welded it back together. Ground the weld Then applied some Bondo on it, sanded that, then painted it black. Looks like factory stock Now. Make sure you scribe a line down the length of the stand before you remove the Section you need to cut out. Then match up the lines when you weld it back together That way the foot of the stand will be in the original orientation with the top half of the Stand, and provide o good foot print |
Exactly what I need to do.. but no welder
![]() Have to wait till corona dies down then I can get to my peeps with welders. |
Ok thank you N.Z.
