Vader engine bolt replacement.
Need help guys!
Has anyone here upgraded their cheap chinese engine bolts to 10.9 grade? I’m looking to swap them out. I need the know the lengths for the two bolts. I’m planing on doing a little dirts works & don’t want the engine to fall out on the trail. Cheers! |
motosport.com all the parts on the frame of your bike will fit on the Honda grom. motor bolts I got them for my bike. and swing arm front fender all so the seat 2015 model year I have the tao tao hell cat it is a 2015 clone of the 2015 Grom.
I believe it's a 120 and 130mm M8 size. You can do a 130 and 140mm so you can double up on nylocs and loctite with some lock washers, just make sure the bolt head is on the chain side so that it doesn't push out the chain guide.
Grom bolts are M10 so I wouldn't recommend doing those unless you want to drill the motor. |
Excellent info.
Thanks so much guys!! Cheers!! |
