Old 04-18-2020, 11:19 PM   #1
nij_tp   nij_tp is offline
(Thicker style) Fork brace
So I had a read of this post after reading Dan's trick and tips.
http://www.chinariders.net/showthread.php?t=19349
I ordered my brace back in april/may last year and I am now getting to put the bike together. I just reread the link and just saw in Nov that someone tried to use the same brace and it was too thick.
I tried to mount it and it didnt fit between the wide part of the forks. Just wondering if anyone else on the forum had tried to use this brace, with success.
This is the brace
amazon.com/exec/obidos/ASIN/B07H1DCFL7/ref=nosim/refuge0d-20
Toys include Audi B7, running Stage 2+, S4 Brakes. My VW Vanagon is running 2.5l VVT Subaru engine, 18" AMG wheels, Porsche 944 Steering Wheel, W eekender interior. 1989 VW Vanagon Bluestar one of 2500, 1986 Honda Shadow, 2000 Suzuki Intruder, 1988 Kawasaki Voyager XII, 1976 Mercury Capri II, a bunch of Trailers including a shortened Vanagon for camping, a Sequoia and the latest addition a 2019 Hawk 250. (But dont tell the wife! ) (Latest latest addition a 1995 fwd Subaru SVX)
Old 04-19-2020, 11:46 AM   #2
roundhouse   roundhouse is offline
roundhouse's Avatar
I have the same brace. I mashed it together until it fit. Takes a little effort to keep it symmetrical but if I can do it anyone can.
It makes a nice difference in the front end feel of the bike.
Old 04-19-2020, 02:05 PM   #3
alex_in_az   alex_in_az is offline
I desperately need one of these, do you have a link to the brace? the one in the OP doesn't work. alternatively what should I search for?
thanks, Alex
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 04-19-2020, 02:35 PM   #4
roundhouse's Avatar
I found this one but the one I got from ebay I cannot find. It was only $29. I think either of these will work with minor modification. Both may have to be bent a little to fit and of course drilled.
https://www.ebay.com/itm/SLOTTED-RAW...QAAOSwnDZUJz4C
https://www.aliexpress.com/item/3292...archweb201603_
Old 04-19-2020, 03:36 PM   #5
Hi RoundHouse when you say mash do you mean large hammer and some beating to make flatter?
Regards
Old 04-19-2020, 04:07 PM   #6
thanks, Alex
\\Heres the one I am talking about (in black)
https://www.amazon.com/exec/obidos/A...im/refuge0d-20
Old 04-19-2020, 04:56 PM   #7
None of them fit perfectly. They are designed for a Harley and thus require modification. I had to "pinch" mine a little to get it to fit
Old 04-19-2020, 05:15 PM   #8
thanks
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 04-20-2020, 08:13 AM   #9
This is the one we all been installing. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Like Megadan stated i also had to pinch it in a little to work.
2004 Honda ST 1300
Old 04-20-2020, 11:28 AM   #10
Unfortunately it is currently unavailable :-(
Old 04-20-2020, 11:45 AM   #11
Yes, that's been the case. I lucked out and bought one when they became available. Just keep checking and it will pop up available again, That's what i did.
2004 Honda ST 1300
Old 04-20-2020, 04:46 PM   #12
Cool thanks, will continue to look. I will try and pinch the one I have but it does look like it is going to put some real outward pressure on the forks. As you can see its not even that close, but Roundhouse says he made it work, so Ill give it a go.
Old 04-20-2020, 05:05 PM   #13
The one you have looks a lot thicker than the one i have. The one he has linked on ebay looks to be the same as i have.
2004 Honda ST 1300
Old 04-21-2020, 05:39 PM   #14
So once brain was engaged..... Reshaped using a vice and some thread and bolts.
When you squeeze with a vice the open ends want to fold in together so needing a way to keep them from doing that i grabbed some threaded rod, fender washers and nuts.
In case anyone else has a blank mind moment like I did :-)
Will post fitted pics soon
Old 04-21-2020, 09:35 PM   #15
roundhouse's Avatar
Smart. I used a piece of 2x6 I cut to the desired length. The bolts may be a better idea.
