Tbr7 on it's way
Hey everyone long time reader first time posting. So i finally took the jump and ordered a bike. After searching all night I'm coming at a stop on ordering some things to do the mods as soon as the bike arrives. I wanna ride it when it gets here haha. So I'm in NH Google says 1000ft for elevation so I'm thinking a 110-120 jet replacement I could be wrong. Should I buy a carb and mod that or take apart the one on the bike? If anyone has active links and listings of the parts needed I would greatly appreciate it. Looked on motochesse website along with the tbr7 post and a lot of links are dead. I know I would like to source a carb kit so I can just buy it all at once, I might need to lower the bike as I have a 29in maybe inseam probably smaller. I'm a short dude haha. I'll make a list so I stop rambling the quarantine has me going crazy. Thanks everyone.
1. Carb and or carb kit 2. Exhaust 3. Shocks? Maybe 4. Sprocket change may do that later if I determine high end isn't enough. 5. Gauge cluster saw one with USB and digital would like to track that down. 6. Any other mods I should do my brains mush been up way too long lately lol. Recommend away and I'll start ordering. Again thanks everyone. |
Welcome Aboard!
Good to know thanks, any exhaust recommendation?
Any of the many CRF230F exhaust you will find on Ebay and Amazon. For Example https://www.amazon.com/dp/B07GYSLJMD...lig_dp_it&th=1
#5 | |
the iridium plug livened up my tbr7 a fair amount.. some say you should use a non resistor plug saying that it could cause premature coil failure.......others just use the iridium plug....
if you can weld you can also just gut the cat and put a plate over the secondary air system on the exhaust.... i am currently running a stock exhaust but am changing to an aftermarket (in the garage now) to allow it to breath... air in air out as they say...
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
#7 | |
Good to know thank you, exhaust is always the last thing i do on bikes anyways.
#9 | |
2020 Tao Motors TBR7 -Mikuni Carb w/110 Jet -17t Front Sprocket -428 HD 130 link chain -Hawk digital cluster |
