04-08-2020, 09:51 PM | #1 |
Removing Decals
Hi all, I'm expecting my Apollo 250cc soon and I was wondering if anyone has removed the numbers that come on the bike? I'm just not a fan of them and was wondering how difficult they are to remove. Thanks
04-09-2020, 08:11 AM | #2 |
Not specific to Apollo, but I recently removed all decals from my TBR7
Buckle down for a nightmare my friend. I tried EVERYTHING!!!! every dumb video on the internet , oil, WD40, GOOF OFF, GOO b GONE...nothing worked well. WHAT WORKED? Heat the decals a bit with blow dryer to remove easier ( will leave glue film behind ) Lots of gasoline on a wet rag and upon saturating the decals, you then take a rough sponge and make small circles to bunch up the glue into sticky balls and then spray the plastic with WD 40 and wipe the glue balls off clean. |
04-09-2020, 01:27 PM | #4 |
mine are pretty much falling off on there own... I have pulled off a few of them already... I am tempted to put a couple RMZ Suzuki stickers I have as a joke but i have to much respect for the Suzuki's I have had so I probably won't
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
04-09-2020, 01:33 PM | #5 |
A heat gun, WD40 & lots of elbow grease!!
Cheers!! |
04-09-2020, 02:30 PM | #6 |
Some easy, some hard
I used a heat gun to loosen them up. Then, I found that some of them came off really easy. The others left goo. I tried acetone first, but it just balled up the goo.
I got some goo-gone and that worked. It took a while, but it worked. I was told by the Hardware guy (in the paint department) to use goo-gone because it is less harsh on plastic than goof-off. But if goo-gone hadn't worked I would have tried goof-off. Here are before and after photos. I left a few decals...just so it wouldn't be all black & white.
CSC TT250 Orion RXB 150XL |
04-09-2020, 07:12 PM | #7 |
I'm all about removing the decals... like my TBR7 look without the decals
04-09-2020, 07:54 PM | #9 | |
04-09-2020, 11:42 PM | #10 |
Freaking cool, just the fact they will come off without a PhD and not take a month! Thank you
04-09-2020, 11:52 PM | #11 |
I'm completely jealous of some of these stories ..... I'd rather snake a waste drain line with my bare hands than remove those decals again
04-10-2020, 11:08 PM | #12 |
HA HA,you guys are lucky my DLX stickers peeled off in my hands as I was working on it.I wasn’t dead set on removing some of them but they all peeled off in less than 5 minutes.
