Old 04-05-2020, 01:08 PM   #1
SSV   SSV is offline
Oil change and type?
My Apollo 250 will be here tomorrow and I know on my old bikes it was just shipping oil and not to leave it in very long before changing it out.
What oil does this bike take? And how long should I wait before changing it out?
Old 04-05-2020, 04:01 PM   #2
Its_not_a_honda   Its_not_a_honda is offline
Go get some 10w 40 MOTORCYCLE oil. Not synthetic. You can switch to that after 1000 miles or so. What ever you do make sure it is "wet clutch" compatible.
Change the oil BEFORE you crank it for the first time. Drive it like you stole it. Change it at 100 miles, 300 miles, then 600 miles. Then change it every 500 to 1000 miles depending on how dusty it is around you.
You probably know you just started the "oil thread" of the month. And I just started the break-in debate. Lol
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 04-05-2020, 09:48 PM   #3
SSV   SSV is offline
Haha alright thank you very much. I will order some oil now.
Old 04-05-2020, 09:58 PM   #4
SSV   SSV is offline
I have looked and I don’t see anything that says wet clutch.
Is this okay to use ? https://www.napaonline.com/en/p/CCA1...+40+motorcycle
Old 04-05-2020, 10:50 PM   #5
https://images.app.goo.gl/NrVpArrFBeQCpsgC7
Just Google "motorcycle wet clutch oil". I think that one you found will work. It should say on the front or at least on the back about wet clutch tho. I now use yamalube 10w 40. At yamaha dealers everywhere!
Edit: says synthetic. Wait until you have broken it in before using synthetic. Your rings will thank you.
Old 04-14-2020, 10:42 PM   #6
jmb1911   jmb1911 is offline
jmb1911's Avatar
I have been using Rotella T4 15w40 with great results. Cheap and readily available from a lot of places, including big box stores like Walmart. It is labeled as diesel oil, but carries the JASO MA rating for wet clutches.
Old 04-14-2020, 11:10 PM   #7
SSV   SSV is offline
How much do you use when doing an oil change?
Old 04-15-2020, 02:41 AM   #8
jmb1911's Avatar
1 Quart
Old 04-15-2020, 05:10 PM   #9
whitelightning85   whitelightning85 is offline
There is a view hole to see the oil level too, just make sure the bike is upright when viewing!
Old 04-15-2020, 09:13 PM   #10
pete   pete is offline
pete's Avatar
Yamalube is Motul 5100 semi synthetic / 7100 full synthetic..
cheaper to buy it branded as Motul..
before 2008 they used Vavoline..
Motorbike / car manufactures recommend to use there semi synthetic oils
to run a new motor in.... Having to use mineral based oils for brake in
is a internet thing...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-16-2020, 06:58 PM   #11
Wild Dog   Wild Dog is offline
Thank you very much, i was looking for that info.. I don't want to overpay for a mfg branded motor oil. When i can buy it to the OEM.
