Old 03-21-2020, 08:32 PM   #1
Goob   Goob is offline
RXB150 New fender/taillight/license light/plate bracket
Another project. I replaced the stock rear fender/taillight with a fender/taillight that will fit a license plate and has a plate light. The new light has 30 LED's, and the old one was about 10...so much brighter.
The last photo shows how I cut down the fender. It was from a lighting kit that my son bought for his XR250 and didn't use. It mounts to the plastics with 2 bolts and then thru the seat mount bolt. I had to cut down the wire tray a bit to get the whole thing to set down enough and replaced the wing nut for the seat with a nyloc bolt/nut.
Also, finally got the carb tuned in. Runs great! I am at a mile high (5280 ft) and ended up with a 97.5 Main and 25 Pilot jet.
I also installed the knob adjuster on the Pilot Jet Screw. It fits in the space available and is easy to adjust. The rubber o-ring and washer from the stock screw didn't come out with the screw, so I decided just to leave them in there. I had to use the stock spring as the one that came with the adjuster was too long. By the way, the install is o-ring, then washer, then spring, then screw.
CSC TT250
Orion RXB 150XL
