03-10-2020, 07:52 PM | #1 |
Brozz 250 NGK plug?
What is the correct ngk plug for my new bashan 250?
03-10-2020, 08:56 PM | #2 |
Many different plugs work and people have so many different opinions on plugs. I can tell you what works well on many china bikes and what works well on my Apollo db36 deluxe. Here it is below:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Actual Plug: NGK (6681) DR8EIX Iridium IX Spark Plug
BuffaloChinaRider on Youtube Bashan Storm 250 (2018) Apollo Db-36 Deluxe (2019) |
03-10-2020, 09:30 PM | #3 |
NGK 2202 will also work.
03-10-2020, 10:40 PM | #4 |
Is the end of that plug compatible with the "threaded" type end of the female spark plug wire? I ordered that exact plug and was just looking at it in the garage questioning if it would fit correctly
03-11-2020, 12:25 PM | #5 |
For a simple, inexpensive, direct cross plug,...the NGK DP8EA-9 (5829) works just fine. OEM in many made-in-japan bikes over the years.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
03-11-2020, 04:20 PM | #6 |
The 2202 has a removable cap so can be use with either type.
03-12-2020, 07:46 PM | #8 | |
03-15-2020, 05:32 PM | #9 |
Does anyone know the difference between the 5829(DP8EA-9) , and the 4929(DPR8EA-9)?
I put the "R" designated one on mine yesterday befor an all day ride, it ran just fine, but if there's a chance it might be damaging in the long run I'll need to change it asap. |
