Hey chinariders!
It's been a while sense I posted here, I've gotten so much help from everyone here years ago on my "Lifanized" Roketa db-06. I'm looking for some more help with a Lifan GY-5 200cc that will be my girlfriends first bike. So me and my brother both have DRZ400's and my brother is completely not interested in selling or doing anything with his GY-5 so he said my girlfriend could have it, but it has some issues. First thing is, second gear is a pain to shift into, Like you gotta stomp it, and hard to get it to go, it wasn't always like. My brother said he did an oil change to see if it would get better, but it did not help, I will start with a fresh oil change my self to see if it gets any better. If it doesn't does anyone have a suggestion on what it could be? Second thing is, the carb spits out a lot of fuel, Like the float is stuck or something ( i've only cleaned a few carbs so im not to experienced with them ). So we had a GY-5 Parts bike, so we took the carb off of that and tried it on his running GY-5 and it did the same thing, which i thought was very strange. Im willing to just replace it with a new one if possible, if anyone could point me in the right direction for one that will bolt and hook right up, just to be done with it. If you have suggestions on it, I am willing to take it apart and have a look inside. Any ideas or help is appreciated Thanks guys!
2021 Boom Vader Gen 2 BD125-10 Current 2011 DRZ400S Current 2006 LIFANIZED ROKETA DB-06 200cc Sold 2008 Ninja 250R Sold 1984 Honda aero 125 Sold 1980 Honda CM400T Sold |
How's the clutch adjustment?
#3 | |
Or, buy a new carb. As far as the second gear problem, it will be hard to diagnose accurately from this side of the computer. What about the other up gears? is 3rd or 4th also hard to engage, or just second? Is second hard to engage going down from 3rd, or up from First/Neutral? Both?
Thanks for the replys!
franque - the clutch adjustment seemed fine, I still have to get the bike out of storage, I plan to this weekend hopefully, I will double check it and report back. Megadan - Thanks that is very helpfull, I will plan to take apart the carb and clean it really good, along with the blow test. Third and fourth gear seem fine, Once you manage to get into second. As for going from Third to second I will have to confirm once I get the bike out, hopefully this weekend. second to first You will occasionally go into neutral some times, but for the most part it goes back into first just fine. Just trying to get a jump start on what i need to look for, getting this this going for spring. I apprecaite it, and i will update you guys on what I find out.
Make sure that you have a little free play, but not too much. Having too much could mean that you're not properly getting the clutch to disengage the transmission (when the clutch lever is pulled in), it'll be difficult to shift. Been there, done that, with a clutch cable that kept re-adjusting itself due to vibration.
#6 | |
As for the carb, once you turn the fuel on, it literally pours out from the float overflow tube. so I'm going to take it apart and see why the float needle inst sealing properly. Also the bike is a bit tall, anyone ever tried to lower a chinabike on here, have any tips, she is about 5' 5'' tall.
Glad it worked out. I'd get her a good pair of boots, and show her that only one foot needs to be down to be safe.
Tags |
carbeurator, gy-5, lf200gy-5, lifan, second gear |
