Old 03-04-2020, 09:06 AM   #1
vtwinaddicted   vtwinaddicted is offline
Doh! 2018 brozz 250 carb mods
Just purchased a brozz 250, 2018, what carb mods should I do? Just the main jet? And what size?
Old 03-04-2020, 09:48 AM   #2
BuffaloChinaRider   BuffaloChinaRider is offline
I would honestly Look inside of the carb on your brozz first. If it hasnt come in yet id just wait to look inside to see the exact size of the main then factor in what your elevation is. Depending on your elevation, your stock main jet may be just right for you who knows! I have only ever changed my main jets and that always help any issues or helped performance. I have pilot jets but I never felt the need to swap them out.
BuffaloChinaRider on Youtube
Bashan Storm 250 (2018)
Apollo Db-36 Deluxe (2019)
Old 03-04-2020, 12:15 PM   #3
cycleway4   cycleway4 is offline
Is this a new purchase? (not a used bike?) you may want to try it as is...I have a 2019,..am at 1000' elevation...and mine is great the way it is...made-in-japan Keihin...starts cold fantastic, with little or no choke,..no stumbles on acceleration,..runs just fine on the road. There have been plenty of Brozz owners who also report leaving the carb as-is...with great results. ***note: the valves most likely will need adjustment before starting,..everyone also reports tight valves, with zero clearance. Tight valves will for sure result in unhappy initial/cold start results, as well as running issues.
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 11-21-2020, 08:26 AM   #4
Jbmoto   Jbmoto is offline
New channel launched!
CHECK OUT AMAZING VIDEOS OF THE Lifan X-PECT AND "MOTO EATS" IN FLORIDA @ SOUTH FLORIDA ADVENTURE SPORTS!
