Brake it too me slowly!
Guys, the front brakes on my Brozz are pathetic. Today I cleaned the front rotor again with degreaser and finished with alcohol. The brakes barely slow down the bike.
I tested the front brake going as low as 9 mph indicated. I’m unable to lock the front wheel squeezing the lever as hard as possible. What to do? I had considered to remove the pads and use some sand paper to possibly deglaze the pads. Has anyone purchased any upgraded pads with more bite? It’d be nice to actually be able to stop instead of just moderately slowing down! |
Did you bleed the brakes yet? May have some air in the lines.
No , I haven’t attempting to bleed the brakes yet. I guess it’s off to auto parts store again. I did change the oil over the weekend. I hit the 100+ mile mark.
I bought a hand pump vacuum brake bleeder from Harbor Freight that work perfect for these bikes.
Thanks!!
Already in my cart. |
#10 |
One, yes, bleed the brakes, and once you feel you have it fully bled and back together, zip tie the brake lever back so it is partially engaged and leave it with the master reservoir as high as it can get for sever hours, tapping on the line and fittings one or two times as it sits like this. The compression of the fluid will reduce the bubble size of any remaining air and help it travel up the system, and the engaged lever will leave the port open to allow air to burp into the reservoir.
As far as the pads go, yes, different pads may help. I upgraded my Hawk from the original pads to a set of sintered pads I found on Taobao and the difference was huge.
#12 |
I forgot all about mentioning that Megadan.
#13 |
Two more tips for bleeding brakes. While at it, change the fluid to a decent DOT 3 and ensure that you don't overfill the reservoir.
#15 |
I flushed all the fluid in my hawk and it helped some but it was not until I hit my rotors with a sanding block and 800 grit sand paper then I pulled the pads and scuffed them up too on a flat surface. It made a big difference. I rode pretty easy on the brakes for 100 miles then when I clamped down they grabbed real good.
I do not know why but the rotors were glazed up. I bought my bike used though. Note: I am not a mechanic and this may not be the right thing to do. It worked for me though. Oh +1 for the pun |
