02-13-2020, 02:18 PM | #2 |
Welcome aboard! Although this thread is for the Hawk 250, Most of this information will apply to the TBR7. http://www.chinariders.net/showthread.php?t=20331
02-14-2020, 11:28 AM | #3 |
Welcome!
02-16-2020, 01:24 AM | #4 |
I also just recieved my TBR7 monday. It's been fun wrenching on it, to get it ready for a long life. Just go ahead and buy a jet kit for it. It's running too lean from factory, to the point the cat glows red in about a minute or two of riding it.
2020 Tao TBR7 2001 Yamaha PW80 Y-Zinger https://www.youtube.com/channel/UCtv..._as=subscriber |
02-17-2020, 09:20 PM | #6 |
Congrats, my son decided to keep the TBR7, so now I have to order another one, or get a hawk!
Here's him riding it tonight http://www.chinariders.net/showthrea...871#post328871
02-22-2020, 10:15 PM | #7 |
Just put a VM 26 Mikuni Carb on my 2020 TBR7 today. Used 110 Main Jet. Wow, Woke this bike up. Runs better than i expected ,doesn't bog or stall in 1st gear anymore. Still working with tuning it in. I didn't want to have to Mod the P30 it came with, will use that as a back up if needed. Highly recommend this mod.
02-22-2020, 11:00 PM | #8 | |
03-08-2020, 10:52 AM | #10 | |
been around bikes for a while.... honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7 all about the Tao MotorsTBR7 http://www.chinariders.net/showthread.php?t=25553 |
03-09-2020, 02:17 PM | #11 |
I also bought and am in the process of assembling the TBR7 and am using that as a checklist of stuff to do while assembling...
So far I have done Grease assemble Front/Rear Axle, Rear Susp Pivot points swing arm, Oil Change, battery charge and install, Chain adjust, Loctite Left side.... I am doing the Valve adjust, Clutch adjust, loctite right side tonight and Carb/Jet Swap, Fork Oil, brake fluid change, lube cables tomorrow. Bearings and front/rear sprockets (changing those bolts to actual Honda bolts) when the back one arrives.. I would guess it's about 10-15 hours of wrench turning now but many more hours of trouble free operation later.... Plus you really get to know your bike this way and YES I did find a few nuts/bolts that were not exactly tight so.... I feel as though there is nothing I haven't taken apart on the bike at this point.
03-14-2020, 02:08 AM | #12 |
One other thing i did that made a big difference was changed that spark plug. Got rid of that D8RTC 115529. Replaced it with a NGK iridium DPR8EIX-9 2202 not much difference in performance, but you can feel it. The biggest thing is in starting the bike. Even with a low battery, it fires right up. Seems to idle much better too. Even from a dead cold start I don't even have to use the choke. I'd recommend this ignition upgrade. The lead acid batteries these bikes come with are junk, this is a great equalizer for under 10 dollars.
03-14-2020, 02:55 PM | #13 |
Greetings from the Sunshine State!
Welcome to the forum!
Congrats on your new bike! Post some pictures if you can! Enjoy the Ride!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
