02-09-2020, 04:41 PM | #1 |
New guy from Northern Ireland
Hi folks just want to say hi.
I have just been giving a 07 JYM 125-3A which is not running right so i would appreciate any help from you all |
02-09-2020, 05:21 PM | #3 |
How do i add photos
02-09-2020, 06:24 PM | #4 |
Hit post reply the click on the paperclip in the tool bar. Search computer or device for picture file and hit upload. Close the file management window then submit post.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-09-2020 at 08:16 PM. |
02-09-2020, 09:16 PM | #6 |
It's a FY125-3A (ViN starts w/ LE8). CG125 jammed in GS125 body which aka "假刀仔" in southern China.
Specs: Older FY case opening are as Honda https://www.motorfans.com.cn/forum.p...authorid=75082 which PiTA to fit a generic CG150 jug into it. === What's the problem ? Adjust valve clearance & change the oil to spec is the 1st thing to do in these pushrod machine. Other normal tear & wear use common sense may solve it...
02-09-2020, 10:45 PM | #7 |
Welcome to here, and you get bonus points for posting photos and the bike had plenty of lighting!! I am a big fan of standard-style bikes, and I do like the idea of a minimalist approach with the 125cc engine (I am guessing you are on an 'L' plate, so 125cc for a reason, but I still appreciate small engine bikes).
02-10-2020, 05:34 AM | #8 |
Problem with the bike is it will only run with choke i have striped the carb and it was spotless apart from some crap in the idle jet which i cleaned out. It does have a cheap pod filter would that be the cause. I have been riding for over 20 years the reason for the 125 was it was free. i also have a 600 bandit but can't use it at the moment as i have a shoulder injury which i am waiting to get surgery on only done about 200 miles in a year so the wee bike will get me out riding again.
02-10-2020, 05:51 AM | #9 |
Vin
Here is frame number if this helps to identify it
02-10-2020, 04:46 PM | #10 |
If this is a gs clone would a suzuki gs airbox fit it?
02-10-2020, 06:31 PM | #11 |
One of the first things i checked as that was what i thought it might have been but thank you for the idea
02-11-2020, 04:53 AM | #12 |
According to https://item.taobao.com/item.htm?id=524257937579 said there's a direct a fit for [仿铃木王顶杆机] The foam is the same btw real & fake
The stock carb http://www.chinariders.net/showthrea...334#post325334 were quite good if doesn't messed up the settings BUT old bike always... 1 of the tricks https://www.motorfans.com.cn/forum.p...authorid=75082
02-11-2020, 05:03 AM | #13 |
Thanks for the info i shall let you know how i get on
02-12-2020, 05:23 PM | #15 |
Welcome, good luck on your surgery, and thanks for the pix!!!!
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome". |
