02-02-2020, 12:50 PM | #1 |
Preparing for Brozz delivery on Monday
I’m preparing for delivery tomorrow and gathering a few items I don’t currently own.
New oil and spark plug and valve feeler gauge, grease gun and grease fittings. I was looking at a simple stand at Harbor freight and maybe a jack. Didn’t really need that jack but I read it was the easiest way to install the shock. Heck my car doesn’t even have a spare tire or jack. My truck does. Is there an easy way to bolt up the shock without using a jack? |
02-02-2020, 01:32 PM | #2 |
In the lack of having an available friend or older child (a second person is ideal assembling these dual-sports), people have tied rope or used tie downs from hooks on their garage ceilings or carports to assemble these.
02-02-2020, 01:35 PM | #3 |
Welcome to the Brozz family! I recommend getting a dirt bike stand, balance it on the stand then you can easily rock it back to line up the shock bolt. it will also make routine maintenance much easier.
2019 Brozz 250 1999 Gas Gas EC300 2003 ZX6R 1991 Voyager XII |
02-02-2020, 01:58 PM | #5 |
Good luck with the new bike ,Do you happen to know is thjer any differance between the carbs on the brozz vs the storm?
02-02-2020, 02:05 PM | #6 |
No , sorry. I just remember the Brozz are supposedly jetted a little richer 105 main jet. I’m at sea level. Something Else to look at.
Does anyone have a link for a upgrade jet kit for Brozz. I assume I’ll have to increase the main to a 110 or 115. Any help her would appreciated! |
02-02-2020, 02:16 PM | #7 |
The 105 works pretty good, I'm around 1000ft though, I went to 110, and it's about perfect for stock exgaust. You'll probably want 115 or 120. Mikuni main jets work fine I found a 105-130 pack on eBay for a few bucks.
02-02-2020, 02:51 PM | #8 |
I would leave the stock carb alone for the break-in period. I am fairly certain both the Brozz and the Storm have the same engine set-up (as well as the BMS CRP 250 and that new motard bike).
02-02-2020, 05:59 PM | #9 |
Lay the bike on it's side. Maybe put a tarp or blanket down if you are worried about scratching anything. That's what I did with my bike.
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
02-02-2020, 06:52 PM | #10 |
Thanks for all the advise. I’ll leave the stock jetting alone for now and see how she runs during the brake in.
I’ve watched a few video on setting the valves lashes. This is something I haven’t done before. So am I safe with .003 on the intake and .004 on the exhaust . And done on a cold engine? |
02-02-2020, 08:58 PM | #11 |
Cold engine, manual calls for .005 on both, I went .005 on intake .006 exhaust, seems to run pretty well.
02-02-2020, 09:26 PM | #12 | |
I’ve heard .002 /.002, .003 /.004 on the lashes |
02-02-2020, 10:44 PM | #13 |
https://brozz250.com/portals/brozz25...s%20manual.pdf
Pg.18(as numbered) You should get a copy with your paperwork as well. Also sorry it's 0.05mm
02-03-2020, 07:22 AM | #14 |
Thanks!
02-03-2020, 09:53 AM | #15 |
I typically do 0.06mm in
0.07/8 ex 2 or 3 tho for those using ancient measures |
