Old 01-28-2020, 03:18 PM   #1
BrianW   BrianW is offline
Location: Wheeling, WV native currently living In Natchitoches, LA
Send a message via AIM to BrianW
Scooter won’t start after being left in rain
Accidentally left my scooter out in the rain and now won’t start. I’ve drained carb and gas tank and replaced the spark plug but still no luck. It just cranks and cranks. Where should I go next?
Old 01-28-2020, 03:25 PM   #2
Check that you didn't accidently hit the kill switch. Kill switch my still have water in it and is grounding out. If you have a leaf blower try blowing out everything to help dry it up.
2004 Honda ST 1300
Old 01-28-2020, 04:21 PM   #3
tortoise   tortoise is offline
Originally Posted by BrianW View Post
my scooter . . just cranks and cranks
Year, brand, model?
Old 01-28-2020, 04:44 PM   #4
Did some testing of the killswitch and still no luck. Wondering if it somehow damaged the cdi?
It’s a 2006(ish) Sunl 50cc standard gy6 with electronic choke
Old 02-01-2020, 12:39 PM   #5
WildHogsScooters   WildHogsScooters is offline
Have you checked to make sure you are getting spark at all? Take your spark plug/ignition coil and hold it up to something metal on the bike (frame, valve cover bolts, etc) and then try to start the bike. If you don't see spark then thats your problem (stator, cdi, coil, killswitch, wiring, etc) but if you do see spark then your problem is elsewhere (fuel or compression) and you can go from there.
Chris
We sell a large variety of new and used scooters from Peace Sports, Tao Motors, Apollo, Jonway, and Coolster with over a decade of experience in sales and service!
Old 02-01-2020, 02:32 PM   #6
I stressed over a similar scooter for an entire day. The premise was that my buddy laid it down while making a left at an intersection and it wouldn't start after that. I checked and double-checked every device and system on the scooter, before realizing it was just in need of a valve adjustment. Can't figure out why the valves picked that moment to present themselves, but they did. I have a thread on it if you're interested.
All of this assumes you have spark.
Old 02-04-2020, 11:11 AM   #7
Ok, verified that i do in fact have spark. However, the plug does not smell strongly of fuel. The peculiar thing, though, is that the bike will not fire even with a shot of ether. Perhaps I’m wrong in assuming it would?
Old 02-04-2020, 11:13 AM   #8
Weld, I would take that thread link if you have it handy. I adjusted the valves on this scooter about 4 months (maybe 25 miles) ago. I can check them again
Old 02-04-2020, 11:26 AM   #9
The pics are fuzzy, thanks to PB holding them hostage. Here you go, Brian: http://www.chinariders.net/showthread.php?t=9421
