Old 01-16-2020, 10:45 AM   #1
diyRdie   diyRdie is offline
diyRdie's Avatar
CG oil cooler questions
I have been using the bad weather time to do all the modding and repairs to the rat magician I can afford before spring. Finally read almost all the posts on the forum about oilcoolers and the picked one out and ordered. Ended up getting THIS
Should get here around FEB 1st. So my 2 questions are:
1. I understand the pump is a "sucking" type and acts as a check valve. Do I need to open an oilcoolers line and drain it separately from the oil sump every time I change oil? Or are you just changing the quart or so in the sump and leaving what is in the cooler?
2. Does anyone monitor they're oil temps? What temps are common to see.
I'd like to use THIS however the max temp is only 275F.
Thanks in advance. -diy
Good judgment comes from experience, and often experience comes from bad judgment.
MY BIKE'S THREAD
Old 01-16-2020, 11:07 AM   #2
I drain mine each time but my coolers are mounted vertical and just disconnect the hose to drain it. I monitor the oil temps and never gone over 190* so that gauge will be fine.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-16-2020, 01:54 PM   #3
diyRdie's Avatar
Thanx Jerry. Can I ask where your oil temp sensor is located?
MY BIKE'S THREAD
Old 01-16-2020, 03:24 PM   #4
My gauge came with an oil drain plug sensor.
2004 Honda ST 1300
Old 01-16-2020, 07:57 PM   #5
Wild Dog   Wild Dog is offline
Now we are talking about oil coolers, oil drain and so on. Do you have a close up of your dual setup???
Old 01-16-2020, 09:02 PM   #6
diyRdie's Avatar
+1
Teach us the way Jerry.
MY BIKE'S THREAD
Old 01-16-2020, 09:40 PM   #7
Just click on the link in my Sig. Most of my mods are linked there.
2004 Honda ST 1300
Old 01-17-2020, 09:16 AM   #8
roundhouse   roundhouse is offline
roundhouse's Avatar
I have that same cooler. I can tell a discernible diff when riding in the summer. Toyed with a dual setup but never pulled the trigger as 1 works fine so far.
Old 01-17-2020, 12:45 PM   #9
OneLeggedRider's Avatar
I'm considering putting one on the Hawk. But I'll just change it a quart at a time and often. Seems like a bunch of fuss and messy to disconnect the lines each time.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 01-17-2020, 01:49 PM   #10
diyRdie's Avatar
Exactly what I was thinking. I change every 1000km now so just keep that up. And with the cooler ,only change the 1 qt. sump oil only. But I was interested in what people are already doing and why.
MY BIKE'S THREAD
Old 01-18-2020, 03:01 AM   #11
That is the exact cooler I have. It works perfectly even with my fender blocking half of the fins.
As far as oil changes go, you don't have to drain the oil every time. While longer oil changes and a higher capacity are nice side effects, the big appeal is a cooler running motor, and it does a great job of doing that even in 100 plus temps. The only way to make it better would be a fan with a thermoswitch.
