01-07-2020, 12:41 PM | #1 |
New Tbr7
Hey my name is Payne, I just bought a new Tbr7. My big question is I'm a little shorter, so how can I lower the bike down?
I know you can take out spacers in the front forks and lower the rear adjustable suspension, just wondering how to do so? Also are there any seats that I can buy to put in, or is cutting the foam the only way to go? Thanks ahead of time! And thanks for everything that's been posted! Super helpful! |
01-08-2020, 12:06 PM | #2 |
Welcome!
The easiest way to lower the front is to simply loosen the triple clamps and slide the forks up a bit. There is a more complex way to shorten the forks if that's your preference, but the method will depend upon whether the forks are conventional or inverted. The rear can be a little tricky, depending on the setup. If a link is used with the rear shock, creating a new link that is longer or shorter can raise or lower the bike, but that requires a little fabrication ability. It's also possible to simply install a shorter shock, but finding one that doesn't have an excessive spring rate might take some trial and error. How much are you looking to lower the bike?
01-08-2020, 01:26 PM | #3 |
Welcome! Great bunch of folks here! Congrats on the Tao TBR7!
01-08-2020, 01:38 PM | #4 |
Payne - The TBR 7 has seat height of 34 inches and there others bikes like it. I'm looking to purchase a bike too but I'm 5'5" so I'll be faced with a similar dilemna. I'd like to know eventually how you solved your height issue.
01-09-2020, 12:49 PM | #5 | |
Thanks for the info so far everyone
-- 2020 Taotao tbr7 |
01-09-2020, 01:07 PM | #6 | |
Email: jeffreyp@peacesports.com Phone: 770-662-1898 x107
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 01-09-2020 at 02:45 PM. |
01-09-2020, 06:08 PM | #7 |
Greetings!
Welcome to the forum!
I’m not sure if it will fit, but CSC sells a seat for the TT250 that lowers the seat height by 2 inches. The TT250 seat fits the Hawk 250. Enjoy the Ride!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
01-09-2020, 06:35 PM | #8 |
Wecome! What color did you get?
01-09-2020, 06:51 PM | #9 |
White, and I did the "fully assembled" option from Tx powersports... I still plan to go through everything. I already bought a new carburetor, main/pilot jets, sparkplug, and oil, that'll I'll replace before I start the bike
Tags |
taotao, taotao 250, taotao tbr7, tbr7 |
