![]() ![]() Also I keep hearing this wiring noise coming from the starter motor, is that bad? |
Bike while running will light up but I’m faking to imagine if dude blown why it lights up, or if it can, take the fuse right out n see.
You only need to unplug the ignition switch to kick start the bike. I’d say you have a dead flat battery and that might be caused by either faulty rectifier or bad connections near there or to the battery. All the ignition switch is doing is joining red from fused red battery wire to black wire that’s ign + and disconnects the kill switch when turned on Turned off it disconnects power but connects kill switch |
So what are you saying I should do, try and charge the battery or should I look for faulty wiring near the starter? I'm a little confused?
That sounds like the starter clutch is not engaging.
Oh! I am a bit new to these things but what would be a proper fix for this situation. Should I work on trying to replace the starter clutch?
Oh okay that sounds easy enough. Thank you! I will try that later today to see if that works.
#9 | |
You will need to pull the current starter clutch to verify what you have. It could possibly be like this one but check before you order. https://www.motopartsmax.com/index.p...roducts_id/666
#10 | |
![]() Quote:
#11 |
Here's a link to more starter clutches so you can try to match up with what you got. https://www.vmcchineseparts.com/coll...clutch-parts-1
#12 | |
#13 |
Parts are common amongst the bikes but vary from manufacturers to manufacturer and would be best to put you hands on the part and verify before buying.
#15 | |
