Hawk 17t sprocket issue
I have a 2019 Hawk DLX and after installing a 17t front sprocket I’m having a hard time getting the sprocket cover back on.
Does it need trimming to fit the larger sprocket or do I need to force it back on ??. |
Jay and I both had to trim ours. About a 3/4" wide section at the front of the cover about 3" long worked for us. And you can't tell unless you pull the cover off. Tried doing it with a dremel but that aluminum is pretty thick. A 4" angle grinder made short work of it though.
I didn’t have to trim mine, but I had to install the cover and then feed the chain through. Don’t know why, but it worked for me.
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
